Extended Diff Breather Problems? #95915 10/15/02 01:17 AM
G
Golden Dragon Offline OP
I read on Yotatech about a guy having problems with his extended breather so he switched it back to the stock version. I think he said something about the length of the hose not being able to equalize the pressure....?
Is someone else having these similar problems? How long should the hose be?
Right of The Line
Re: Extended Diff Breather Problems? #95916 10/15/02 01:31 AM
no probs here
Re: Extended Diff Breather Problems? #95917 10/15/02 02:24 AM
surlynkid Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Golden Dragon:
<strong>I read on Yotatech about a guy having problems with his extended breather so he switched it back to the stock version. I think he said something about the length of the hose not being able to equalize the pressure....?
Is someone else having these similar problems? How long should the hose be?</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">sounds like BS to me. mine work fine.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Extended Diff Breather Problems? #95918 10/15/02 03:09 AM
4Crawler Offline
Is someone else having these similar problems? How long should the hose be?</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Lenght is not an issue, but what will cause problems is if there are any dips in the line as it runs. Oil mist will condense until the oil plugs the tube. Will be OK when warm, but in cold weather 90W is pretty thick and it'll allow pressure to rise in the axle and possibly force oil past the seals. I had this problem on my '85 4Runner, lots two axle and one pinion seal before re-routing the line to run upwards all the way to the vent. One vent in front and one vent in back was my fix.
Diff breather info
Re: Extended Diff Breather Problems? #95919 10/15/02 03:36 AM
larsdennert Offline
Wow, that's much better advice than my "It has to be 4.62 feet long to be the proper resonance to the axle housing." That's for on key in C.
Re: Extended Diff Breather Problems? #95920 10/15/02 03:41 AM
G
Right of The Line
Re: Extended Diff Breather Problems? #95921 10/15/02 04:27 AM
4Crawler Offline
The lines get clogged because they aren't run in an upward slope. If there are any dips in the line oil WILL pool there and plug the line. If you run the rear axle line to the front of the vehicle, it'll be very hard to avoid having a dip in the line. Run to the rear and always upward and you won't have a problem. Mine has been fine since I re-routed the rear hose about 4 years ago.
Re: Extended Diff Breather Problems? #95922 10/15/02 04:40 AM
G
Ok Thanks for the tip
Right of The Line
Re: Extended Diff Breather Problems? #95923 10/15/02 05:20 AM
4Crawler Offline
You basically want to make sure that if any oil collects in the line, it'll drain back into the diff. Run a filter on the end of the hose to allow it to breath (vs. running the stock breather on the end). This lets air out and into the axle to keep the pressure equal inside and outside the axle.
Re: Extended Diff Breather Problems? #95924 10/15/02 07:21 AM
Robinhood150 Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by 4Crawler:
<strong>The lines get clogged because they aren't run in an upward slope. If there are any dips in the line oil WILL pool there and plug the line. If you run the rear axle line to the front of the vehicle, it'll be very hard to avoid having a dip in the line. Run to the rear and always upward and you won't have a problem. Mine has been fine since I re-routed the rear hose about 4 years ago.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Hmm...that's probably what happened to mine, especially since I used window washer tube which had a too small ID. But since I shortened it and re-routed it, it seems to be fine.
Steve
Steve
My Website ||Gettin' off 4wheel drive club member
'93 4Runner V6 4x4 auto tranny
If you have to ask about a SAS, you're not ready for it.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6398 MB (Peak: 0.7622 MB) Data Comp: Off Server Time: 2026-06-23 04:51:36 UTC
