front wiper arm removal #1026132 04/06/11 09:14 PM
toyrker Offline OP
Can't remove front wiper arms after using PB blaster due to terrible rust. Was able to remove nuts but arms still stuck on threaded shaft. Any pullers or advice?
85 4runner, 22re,cam, headers,2.25free flow exhaust,3"susp lift, 33's,custom bumpers,& stuff
Re: front wiper arm removal [Re: toyrker] #1026133 04/07/11 12:27 AM
OOP'S Offline
Soak it with PB Blaster and let it set overnight.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: front wiper arm removal [Re: OOP'S] #1026134 04/07/11 07:32 PM
toyrker Offline OP
Tried PB 2 days with intermitent <img src="/forums/images/graemlins/confused.gif" alt="" /> spraying..no luck. How can I pull these? After spraying and not loose. I live at the beach and there is harsh salt air.
Re: front wiper arm removal [Re: toyrker] #1026135 04/07/11 07:42 PM
4Crawler Offline
If you have a small torch, try heating up the center stud until is smokes a little and see if that will free it up. Make sure not to heat anything non-metal and use a small pin-point flame/pencil torch (like below), not a big flame/tip like you screw into a larger tank.
And when it is hot, try melting a little candle wax onto the center and let that wick down into the splines. Should be able to find a small puller at a hardware/auto parts store that may work as well.
Re: front wiper arm removal [Re: toyrker] #1026136 04/07/11 07:43 PM
G
Greg_Canada Offline
Heat? Make sure you cover everything up well tho. a puller would work too if you had one.
89 4Runner
Re: front wiper arm removal [Re: toyrker] #1026137 04/08/11 03:36 AM
toyrker Offline OP
<img src="/forums/images/graemlins/cheers.gif" alt="" /> Found a puller at the ACE hardware.. It is used to pull faucet handles off of threaded shafts. Thanks <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6090 MB (Peak: 0.6785 MB) Data Comp: Off Server Time: 2026-05-29 15:33:03 UTC
