Transfer case compatibility #1026287 04/11/11 12:44 AM
E
evileric Offline OP
Will the gen 2 transfer case bolt up to a gen 1 4cyl w/ an automatic? how much more wiring is there?
1995 Montero SR factory air locker,33x12.50x15 At's
Re: Transfer case compatibility [Re: evileric] #1026288 04/11/11 01:15 AM
E
evileric Offline OP
I want to use Marks4wd 3.15 gears in the gen 2 tcase. Also, i've tried looking and searching, where do you get the 5.29 diff gears?
Re: Transfer case compatibility [Re: evileric] #1026289 04/11/11 03:45 AM
5.29's are in the for sale section right now, if you don't buy those you will have a tough time finding more later at least at that price.
you can use a super select transfer case from a gen 2 with a 12v 3.0 but you will need custom driveshafts. and that t-case still takes Marks 2.85 gear set. In order to run the big t-case and 3.15's you'll need the gen 2 tailhousing to match the transfer case. you'd be better off swapping in a rubicon rock trac t-case at that point as they bolt up and are 4:1. You'd still need custom driveshafts and speedo like you will with the gen 2 cases. What are your plans for the truck? how are you going to use it?
Re: Transfer case compatibility [Re: TOASTY] #1026290 04/11/11 04:06 AM
E
evileric Offline OP
will those only fit V6 diffs? does the rubicon rock trac tcase bolt to the automatic transmission? does it need adapters? i was gonna make HD shafts anyway. its a stripped down shell w/ 2 seats and stock driveline, its a offroad rockcrawler, never on the road. 35" krawler T/A's on MRW beadlocks.
Re: Transfer case compatibility [Re: evileric] #1026291 04/11/11 07:21 AM
yes the 5.29?s are a v6 axle thing, i think they were an option for the 4 cyl axles but are near impossible to get.
The rock trac will bolt up top the 12v 3.0 and 4cyl transmissions, but you need to get the short input shaft model (Rock trac NV241 short shaft) otherwise you?ll need a clocking ring or a good band saw to shorten the shaft.
Re: Transfer case compatibility [Re: TOASTY] #1026292 04/11/11 03:45 PM
E
evileric Offline OP
does it matter what gen the axles are? i was searching a couple days ago and found a link to the aus website who sells the 5.29's, cant find it now. ok thanks for the help man.
Re: Transfer case compatibility [Re: evileric] #1026293 04/11/11 06:40 PM
Gen 1 8"front axles are low pinion and gen 2 8"is high pinion.
Re: Transfer case compatibility [Re: TOASTY] #1026294 04/12/11 12:57 AM
E
evileric Offline OP
thanks i appreciate the help.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6213 MB (Peak: 0.7043 MB) Data Comp: Off Server Time: 2026-06-23 14:19:06 UTC
