3.5 dohc rear view #1026536 04/14/11 01:30 AM
mxmikie Offline OP
who has a picture of the back of a 3.5 dohc water pipes ?????
Re: 3.5 dohc rear view [Re: mxmikie] #1026537 04/14/11 01:46 AM
I took a look but do not have a shot of the back. I have a block in the shop that I could put heads on and the pipes if no one else has a pic.
Re: 3.5 dohc rear view [Re: mxmikie] #1026538 04/14/11 03:42 AM
SRTNate Offline
1989 Mitsubishi Montero SWB 0.0L (3.5L soon?) Auto, Front LSD, Rear SR Locker, Aisin hubs, Safari Snorkel, ARB Front Bumper, Warn M8000, Bushwacker Flares
1984 Mitsubishi Montero
2005 Dodge SRT-4
1970 Plymouth 'Cuda (in pieces)
...and a few others less interesting.
Re: 3.5 dohc rear view [Re: SRTNate] #1026539 04/14/11 11:48 AM
mxmikie Offline OP
where does the heater hose pipe on the right go into the motor ?????
Re: 3.5 dohc rear view [Re: mxmikie] #1026540 04/14/11 12:04 PM
That one goes into the back of the waterpump.
Re: 3.5 dohc rear view [Re: OldColt] #1026541 04/14/11 01:42 PM
mxmikie Offline OP
i got it water pipes
Re: 3.5 dohc rear view [Re: mxmikie] #1026542 04/15/11 03:37 AM
mxmikie Offline OP
i had a water leak at the back of the block turns out to be the water pump leaking from the weep hole it filled up the valley of the block and was running down the trans i replaced the heater hoses but could not see the water in the valley a bright flashlight and a mirror found the problem good thing i had the hoses and a new water pump "in stock" i went ahead and put a new radiator in it since i have a couple sitting around with nothing to do ..... as i get older this thing is getting to be like my truck ...... like to drive but hate to work on it ......... think i will sell it and replace it with my subaru outback....... thanks for the pirtures
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6223 MB (Peak: 0.6970 MB) Data Comp: Off Server Time: 2026-05-29 14:44:13 UTC
