Logging into 4x4wire from Droid
#1026543
04/14/11 03:44 AM
I had to replace my Droid the other day. I have been unable to login to this site since. It says my username/password combo is not valid. I'm POSITIVE I'm entering it properly, and I never had a problem from the phone before. Anyone know what gives?
Re: Logging into 4x4wire from Droid
[Re: stony-man]
#1026544
04/14/11 11:08 AM
I just had the same experience on my home PC. Sounds like a login issue on the wire.
Frank
[Re: FrankR]
#1026545
04/14/11 05:31 PM
It is more of a login issue with your cookies.
Under the "MY HOME" tab is a "Main Configuration" panel. The bottom line is titled: Maintenance and has a selection "My Cookies"
Select that and then select the option to "expire cookies". You will be logged out and it should clear all of the session cookies.
It is the session cookies that can become corrupt and cause weird problems with login and display.
I have had a periodic problem with my Droid phone but no problems with my iPad.
Any problems, drop me an email as I periodically have to expire cookies for someone's login.
[Re: 4x4Wire]
#1026546
04/15/11 04:19 AM
Thanks! I expired my cookies here, and that didn't do it. But your advice made me think to do the same on the Droid, and that did it. I cleared everything I could from the phone, and I was able to login immediately. Thanks again!
Keith
[Re: stony-man]
#1026547
04/15/11 01:11 PM
Toyota Moderator
I regularly log into 4x4wire.com using my Droid-X without any problems.. So would agree, must be a cookie related issue, or incorrect saved password.....
Getting inadvertent wrong passwords out of the browser can be a problem sometimes....
2000 4Runner,V6,Auto,31's, Sliders, Skids, On-Board Air, Air Shocks Related Interests: Welding, Ham Radio, Road Tripping (Blue Highways), High End Video/Audio Systems
[Re: Dandeman]
#1026548
04/16/11 07:09 PM
Any thoughts about adding a Tapatalk plug-in for the forum? Makes surfing forums from a phone really nice & simple. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'97 T100 SR5 XCab 4WD TRD SC ~ ARB ~ FWC '85 FJ60 Landcruiser 4E9 ~ locked ~ 33's
[Re: Creeper]
#1026549
04/17/11 06:07 AM
I will check out the compatibility...
[Re: 4x4Wire]
#1026550
04/17/11 06:19 AM
After reading the info, TapaTalk is not compatible with the ubbThreads forum software.
There is an effort to make it available in coming upgrades to the forum. However, it appears there will be a development cost with a server side requirement that is not clearly defined.
So, currently, it cannot be implemented. I will keep watching the development progress.
