Re: BRAKES R US SLOTTED AND CROSS DRILLED BRAKE ROTORS [Re: 87monty] #1026659 04/16/11 05:41 AM
87monty Offline OP
I know this is off topic but here is my trailer.
This is the hatch side and needs more bracing but is coming along...
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: BRAKES R US SLOTTED AND CROSS DRILLED BRAKE ROTORS [Re: 87monty] #1026660 04/16/11 01:31 PM
JAVYPRO Offline
That is one masterful piece of work. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Keep the pics coming.
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: BRAKES R US SLOTTED AND CROSS DRILLED BRAKE ROTORS [Re: JAVYPRO] #1026661 04/16/11 04:14 PM
87monty Offline OP
Thanks Javy for the comment, This trailer is going to be so cool I cant wait. I could post a new link on the build if you guys have intrest in it. <img src="/forums/images/graemlins/smile.gif" alt="" />
96 SR
Re: BRAKES R US SLOTTED AND CROSS DRILLED BRAKE ROTORS [Re: 87monty] #1026662 04/16/11 04:36 PM
Inyo_man Offline
I recently replaced my rotors and entertained the idea of drilled/slotted product. One of the better product I found was through "stainlesssteelbrakes" :
http://www.ssbrakes.com/
They claim the problem of cracking is reduced through their manufacturing process. I ended up going with OEM product, mostly because of the price.
Occasional use of brake cleaner (especially after wheeling) really helps with squeaking pads/rotors when you don't have hose handy to rinse them down.
Good Luck
'02 Montero: OME suspension, ARB front bumper, homemade skid plates & spare tire Blitz can mount, extended diff. breather, K&N air filter, Optima Yellow Top, BajaRack, IPF lights, Goodyear Duratrac 265/75/16's, RUD 4x4 Grip chains
Re: BRAKES R US SLOTTED AND CROSS DRILLED BRAKE ROTORS [Re: 87monty] #1026663 04/16/11 05:14 PM
Kevin C Offline
Nice trailer!!! I have always wanted one like that.
Re: BRAKES R US SLOTTED AND CROSS DRILLED BRAKE ROTORS [Re: 87monty] #1026664 04/16/11 05:44 PM
plh Offline
I could post a new link on the build if you guys have interest in it. <img src="/forums/images/graemlins/smile.gif" alt="" />
A build thread would be cool. Nice trailer!!!
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: BRAKES R US SLOTTED AND CROSS DRILLED BRAKE ROTORS [Re: plh] #1026665 04/16/11 05:56 PM
Jason,
I have a V6 brake setup for your Montero. Just sayin'
Russell
Re: BRAKES R US SLOTTED AND CROSS DRILLED BRAKE ROTORS [Re: rxinhed] #1026666 04/16/11 06:35 PM
ryany Offline
If you didn't have your rotors turned when you replaced your pads, you could de-glaze your rotors with an abrasive pad attached to a grinder or drill - the techs at the dealership I used to work at would do this when a customer was having brake squealing issues. All you're trying to do is roughen up the surface, not to take off any significant amount of material off or put any deep scratches in it, so don't use anything too coarse. It's easiest to do it with the rotors off the vehicle but if you have a small enough pad you can just pull the caliper out of the way to access the back side. Make sure you have all the anti-squeal shims in place on the backs of the pads also, they really do work.
95 Montero SR
Re: BRAKES R US SLOTTED AND CROSS DRILLED BRAKE ROTORS [Re: rxinhed] #1026667 04/17/11 01:37 AM
87monty Offline OP
Jason,
Russell
Russ I just might take you up on that!
Thanks Guys on the trailer I will post a new topic today for everyone!
96 SR
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6359 MB (Peak: 0.7560 MB) Data Comp: Off Server Time: 2026-05-29 15:37:34 UTC
