dual battery advice #1026678 04/16/11 12:44 AM
belijose Offline OP
last week I went wheeling with a friend and I got stuck pretty bad. I started using my winch and notice that the winch consumes more power than what the alt can charge. I already knew this so I decide to get an aux battery. I already have the battery but I dont know how to connect them. I know that if I connect the +'ves and -'ves both battery will drain at the same time. I want just the aux to drain when winching living the other to run the car. I have research and it looks like a good option are some voltage sensitive relay that automatically switch between batteries. however, I don't know if this relays work even when the motor is running.
has any body done this in his truck ? what are your advices? thanks
1989 Dodge Raider v6 3.0 L, MT.
Re: dual battery advice [Re: belijose] #1026679 04/16/11 03:55 AM
Skibane Offline
Most RV and boating supply stores sell a "battery isolator relay" for 20-35 bucks. The two contacts this relay can be connected between the positive terminals of your starting and auxiliary batteries. The relay coil can be connected to the "run" position on your ignition switch, so that the coil is only energized when the engine is running. Finally, the negative post of your auxiliary battery is connected to chassis ground, same as your starting battery.
RESULT: Both batteries are connected in parallel whenever the engine is running (thereby allowing the alternator to charge them both), but isolated when the ignition switch is turned off.
This is the same scheme that most motor homes and many boats use - It's simple, and effective.
The Redneck Special: 88 Ram 50 2WD XCab with 167K on the original 2.6L, 5-Sp, Weber 38DGS, Crane HI-6 with timing adjust, 4-for-$100 tires, Generac 4000EXL 4KW AC generator, Hampton Bay 12KBTU window air conditioner sticking through a hole hacked in the back of the cab...All it needs now is a gun rack...
Re: dual battery advice [Re: belijose] #1026680 04/16/11 04:03 AM
Inyo_man Offline
My brother has a duel battery with one as a designated starter and the other for all of his aux. electrical. He went with an isolator to do the job of charging when needed. Check out the "painless" site:
http://www.painlessperformance.com/...partsearch=isolator&submit=Go%21
A simple phone call to one of their reps. will give you tons of info. about suggested components for your situation.
To monitor the battery charge he installed a vdo gauge with a toggle that can switch between each battery.
Hope it helps.
'02 Montero: OME suspension, ARB front bumper, homemade skid plates & spare tire Blitz can mount, extended diff. breather, K&N air filter, Optima Yellow Top, BajaRack, IPF lights, Goodyear Duratrac 265/75/16's, RUD 4x4 Grip chains
Re: dual battery advice [Re: Inyo_man] #1026681 04/16/11 05:42 AM
belijose Offline OP
I would check that out. thanks for the info
Re: dual battery advice [Re: Skibane] #1026682 04/16/11 05:44 AM
belijose Offline OP
I am gonna look for that relay online and see what's out there thanks.
Re: dual battery advice [Re: belijose] #1026683 04/16/11 06:48 PM
ryany Offline
Solve the problem instead of putting a band-aid on it. Upgrade your alternator to something that can handle the draw of the winch, coupled with a good AGM battery and you won't have to worry about dual batteries.
95 Montero SR
Re: dual battery advice [Re: ryany] #1026684 04/20/11 10:30 PM
Scottie2113 Offline
totally recommend the dual battery setup with AGM batteries.
this way, you can use a fridge all night along with lights and other accessories and start your truck in the morning after camping.
all you really need is a high amp relay to handle the current that your alt puts out.
you put this between the batteries on the + cable and trigger it with an ignition wire from your key.
when key is off, batteries are isolated
when key is on, batteries connected so you have maximum starting power and then both recharge as you run the truck.
my brother went camping with us and had his fridge on over night; couldn't start his truck in the morning smile
If you plan to use a fridge or other accessories far in the outback areas, it is always a good idea to have two batteries running your system, especially if you go alone smile
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6207 MB (Peak: 0.7113 MB) Data Comp: Off Server Time: 2026-05-29 15:38:04 UTC
