Page 5 of 5 1 2 3 4 5
Re: Gen1 Transfer Cases Options [Re: RECON45] #1026891 03/02/12 07:09 PM
LandRaider Offline
on my 231 I hacked the handle off the shifter, and welded on a chromed steel rod that was bent like I needed it to be. I slotted the floorboard with a jigsaw, and then used some rubber matting with a slit in it to work as the floor seal. Then I got a K5Blazer Boot, and used it to cut out a ring, and screwed that all to the floor.
Re: Gen1 Transfer Cases Options [Re: LandRaider] #1026892 03/02/12 07:11 PM
LandRaider Offline
Here's a pic. Notice the location... This is with a 700r4, and GM motor, so it has little bearing on where yours would need to go.
http://alliedpaper.org/landraider/SASpics%20%2812%29.JPG
LARGE picture
Re: Gen1 Transfer Cases Options [Re: LandRaider] #1026893 03/02/12 08:01 PM
RECON45 Offline OP
Very clean. If I had carpeting for mine, I might would consider that route. I think I got most everything figured out now. it is now a matter of having a few clear weather days to work on it to get everything swaped. Thanks for the input and picture.
Re: Gen1 Transfer Cases Options [Re: RECON45] #1026894 03/06/12 09:34 PM
RECON45 Offline OP
I will try to get pictures but I have a mcmaster carr shifter and 6' cable to use for my shifting. i need to fab a bracket for the shifter to hold it to the floor and a bracket for the cable part to the Tcase. there really is much of a place to set up a bracket that bolts up to the tcase. i will try to get pictures. I want to see if I can use the factory shifter knob on the new set up. i might have to mod it a little bit.
Re: Gen1 Transfer Cases Options [Re: RECON45] #1026895 03/07/12 03:03 AM
I got my Dana 300. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Gen1 Transfer Cases Options [Re: Mudraider] #1026896 06/05/12 10:20 PM
dsmguy Offline
the 4cyl raider transfercase and upgrade for the mighty max? the only thing i see different is that is has the nuetral position and mine does not.
89 Raider V6 5 speed factory lsd rear
88 mighty max 4 cyl. 5 speed
Re: Gen1 Transfer Cases Options [Re: RECON45] #1104154 02/03/18 04:31 AM
djacidjac Offline
I'm exploring options. I was hoping to fit some kind of under-drive box like the BlackBox from NorthWest Fabworks. I've been googling for a couple of hours and all I can find is some vague "23 spline" talk.
Does anybody know for sure what are the shaft specs on a gen 1, 2.6, manual KM-145 transmission:
1. transmission output shaft
a. diameter
b. spline count
c. usable/spline length
2. transfer case
a. (will be same as above)
b. (will be same as above)
c. usable/spline depth
3. any other info related (such as what adapters or cases have the same bolt pattern, what model name/number the transfer case is, etc)
87 Dodge Raider 5sp 2.6l no jet valves, Tuffpan
OME Dakar leaf springs + T-bar crank + 2" body lift (4" lift).
5500lb winch, Starion alternator, grp31 marine bat'
OBA (stock AC compressor)
33x12.5x15 Baja Claws or Wintermark extra load 235/75/15 M/S
Re: Gen1 Transfer Cases Options [Re: RECON45] #1104164 02/03/18 06:50 PM
Mark's in Australia sell a 2.85 low gear set. They've had 3.15 in the past. Look up Toasty or Josh on Adventure Driven Design (.com), as I believe they're marketing the kits.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6336 MB (Peak: 0.7489 MB) Data Comp: Off Server Time: 2026-10-24 03:23:16 UTC
