Tried using different front coils, full of FAIL - lots of pics #1027177 04/24/11 09:47 PM
jagerMR Offline OP
Well...got teh front end done up today. But sagged back down soon as i let the jack down. <img src="/forums/images/graemlins/frown.gif" alt="" />
Thought the coils wouldnt compress as much. So much for trying something different.
These are the springs used, front was roughly 17" un compressed, rears were 15" uncompressed. Rears worked fine.
So, now what to do. Think i need to contact everett...
Kia on floor jack from passenger side...
Off jack...
Re: Tried using different front coils, full of FAIL - lots of pics [Re: jagerMR] #1027178 04/25/11 01:34 AM
4x4Wire Offline
Who provided the springs you used???
I seem to recall you were using TJ springs??
If so, which springs did you get?
Not all TJ springs are created equal. Do a search for American Expediitionary Vehicles. They have some info on the various TJ/JK spring offerings. Also, the Jeep Tech forums had a thread about the springs and other apps. It was 2 or 4 months ago.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Tried using different front coils, full of FAIL - lots of pics [Re: jagerMR] #1027179 04/25/11 08:30 PM
logansportage Offline
The front coils from the JK will not work. They compress too much because the wire diameter is not large enough to provide the stiffness needed to keep the front of the Sportage up. You are probably sitting on the bump stops in your shocks. Probably not a good idea to drive it until you put the correct springs back in.
You can't use the front coils from a TJ either becasue the outside diameter of the coil is larger than will fit inside the upper front mount.
The best option is to either take your stock spring and send it to a spring company to replace with a longer one, or use a spacer like the Up your KIA unit to push the spring down to get the extra lift.
Re: Tried using different front coils, full of FAIL - lots of pics [Re: logansportage] #1027180 04/26/11 09:49 AM
hadtomer Offline
why go for questionable solutions when you can buy aftermarket springs for the sporty straight off the shelf? i can undestand the rear TJ conversion-makes sense and fits well-but why mess with the front springs-which are hard to install and have a severe effect on steering, when you can simply buy an aftermarket spring set which is made by a known company and was probably lab tested and has a quality certificate.
king springs, lovells, eibach, dobinson- they all make front lift springs for the sporty. i have a set of 2 inch lovells lift springs up front and they are great. soon i will be going for bigger lift - and i will be installing a set of 3 inch DOBINSON springs + longer front forks fron TRACKFINGER- that will give me serious lift at the front without compromising the driveshafts.
2001 sporty. 4 inch lift+ body lift-front lovlells coils+extended forks. reat tj. monroe shocks. full skid plate, auxilary fan. external oil cooler. maxxis 8060 235/75 R15 tires on american racing wheels. trackfinder rear diff lock.
http://www.cardomain.com/ride/3948684/2001-kia-sportage
Re: Tried using different front coils, full of FAIL - lots of pics [Re: hadtomer] #1027181 04/29/11 07:32 PM
The problem is Eibach no longer makes the springs for the first generation Sportage, and the other spring companies you mention do not import their springs to the states. The only option we have here for lift springs from a large company was from Eibach.
Dave at Rocksportage Gear made some that gave you a 4" all spring lift, but they were limited quantity. I'm not sure if he still makes them, or not.
Re: Tried using different front coils, full of FAIL - lots of pics [Re: logansportage] #1027182 04/30/11 04:42 AM
hadtomer Offline
so what? almost none ot the stuff on my sporty is imported here by dealers- and yet i have managed to get anything that i need.
I really dont thing that the fact that these parts can not be store bought in the US is a problem. as long as the product exists and is sold on ebay-you can ship it. if shipment is expensive-try shipment by sea- its much cheaper than air shipping.
here is a set of 2 inch king springs on ebay OZ:
http://cgi.ebay.com.au/Kia-Sportage-JA-M...=item2c5a6abf25
Re: Tried using different front coils, full of FAIL - lots of pics [Re: hadtomer] #1027183 05/02/11 06:45 PM
If you notice, this company will not ship to the states. Only options for shipping are OZ or NZ.
Most of the time shipping even by ship is more than the cost of the item. Makes it very cost prohibitive to get something in single quantity. Also the cost for the import fees jacks it up even more.
Re: Tried using different front coils, full of FAIL - lots of pics [Re: logansportage] #1027184 05/03/11 03:18 PM
DennisThompson Offline
It does say you can make arangments depending where you live, If you want them I'm sure you can find a way to get them here, just contact the seller.
Dennis
Re: Tried using different front coils, full of FAIL - lots of pics [Re: DennisThompson] #1027185 05/03/11 11:05 PM
Yes, it's all a matter of time and money. Neither of which most of us have. After all, we drive KIA Sportages. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6325 MB (Peak: 0.7384 MB) Data Comp: Off Server Time: 2026-10-24 03:23:04 UTC
