Anyone ever replace....... #1027225 04/26/11 02:49 AM
toyotadriver Offline OP
The camshaft plug?
I just replaced the valve cover gaskets and I still have an oil seep. I also replaced the RTV on the little half moon aluminum piece but have a seep from behind the cam on each head. The part is #14 in this illustration.
I have to replace them and want to do it without removing the heads. Anyone done it and have any advise??
Thanks.
http://www.trademotion.com/partlocator/i...p;Sectionids=10,4117&groupid=10007&subgroupid=61318&componentid=0&make=34&model=T100&year=1996&graphicID=F809084&callout=14&catalogid=1&displayCatalogid=0
Re: Anyone ever replace....... [Re: toyotadriver] #1027226 04/27/11 05:46 AM
BamZipPow Offline
Can't see the image or link... <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Anyone ever replace....... [Re: toyotadriver] #1027227 04/28/11 04:39 PM
ErikB Offline
Toyota Moderator
I think I see them at the back ends of the heads on page EM-28 here http://www.ncttora.com/fsm/1996/SIL/tech...cylhea/comp.pdf
But I don't think I've never messed with those.
http://home.4x4wire.com/erik
Re: Anyone ever replace....... [Re: ErikB] #1027228 04/29/11 01:55 AM
Thanks for the info. I think that I'd have to pull the valve covers again. I'll probably clean it super well and then spread a little RTV on it and call it good. It's a slight seep and not a true leak. Just bugs me.
Re: Anyone ever replace....... [Re: toyotadriver] #1027229 04/30/11 06:26 PM
BamZipPow Offline
Make sure you allow it to setup before you torque it down. It may be squeezing out the RTV if it's not set when you torque it down. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Anyone ever replace....... [Re: toyotadriver] #1027230 05/05/11 05:11 PM
Don Tibbetts Offline
I just changed my valve cover gaskets and I did not replace this seal. I don't see how you'd do it without taking the valve covers off again. And I see why you don't want to take them off again.
97 T100 4WD SR5 - 231K
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6078 MB (Peak: 0.6777 MB) Data Comp: Off Server Time: 2026-07-15 02:06:05 UTC
