Anyone ever replace.......
#1027225
04/26/11 02:49 AM
The camshaft plug? I just replaced the valve cover gaskets and I still have an oil seep. I also replaced the RTV on the little half moon aluminum piece but have a seep from behind the cam on each head. The part is #14 in this illustration. I have to replace them and want to do it without removing the heads. Anyone done it and have any advise?? Thanks. http://www.trademotion.com/partlocator/i...p;Sectionids=10,4117&groupid=10007&subgroupid=61318&componentid=0&make=34&model=T100&year=1996&graphicID=F809084&callout=14&catalogid=1&displayCatalogid=0
Re: Anyone ever replace.......
[Re: toyotadriver]
#1027226
04/27/11 05:46 AM
Can't see the image or link... <img src="/forums/images/graemlins/frown.gif" alt="" />
[Re: ErikB]
#1027228
04/29/11 01:55 AM
Thanks for the info. I think that I'd have to pull the valve covers again. I'll probably clean it super well and then spread a little RTV on it and call it good. It's a slight seep and not a true leak. Just bugs me.
[Re: toyotadriver]
#1027229
04/30/11 06:26 PM
Make sure you allow it to setup before you torque it down. It may be squeezing out the RTV if it's not set when you torque it down. <img src="/forums/images/graemlins/wink.gif" alt="" />
[Re: toyotadriver]
#1027230
05/05/11 05:11 PM
I just changed my valve cover gaskets and I did not replace this seal. I don't see how you'd do it without taking the valve covers off again. And I see why you don't want to take them off again.
97 T100 4WD SR5 - 231K
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6083 MB (Peak: 0.6783 MB) Data Comp: Off Server Time: 2026-06-07 06:10:35 UTCValid HTML 5 and Valid CSS
