Source for rubber bumpers on A-arm. #1027267 04/27/11 05:29 AM
E
EtienneNavaar Offline OP
I'm not sure I'm using the right terminology but on the front of my '86 there are 2 small (1 1/2" diameter) rubber bumpers on the upper A-arms that the lower A-arms bump up against. Is there a source for these other than the dealer?
Thanks.
Re: Source for rubber bumpers on A-arm. [Re: EtienneNavaar] #1027268 04/27/11 06:49 AM
Snowtoy Offline
The correct term is bump stops. You might find some used ones on ebay or at car-parts.com. A google search might turn up some polyurethane replacements.
Re: Source for rubber bumpers on A-arm. [Re: Snowtoy] #1027269 04/27/11 09:05 PM
RatLabGuy Offline
Poly Performance sells them in both rubber and polyurethane IIRC.
The truth is any aftermarket version will work, IIRC in the frame it is just a hole, the rubber is like a stopper wit ha bolr stud sticking out, this goes through teh hole and a nut goes on other side.
Question Reality.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5938 MB (Peak: 0.6466 MB) Data Comp: Off Server Time: 2026-10-24 03:23:03 UTC
