rear brake troubles-diagnose #1027320 04/27/11 07:47 PM
coup Offline OP
i heard brake noise today,,,,,,removed rear drum for inspect,,,greassy looking but not sure if it is wheel cylinder or axle lube....can i step on brakes while someone looks? if it is wheel cylinder does everyone replace cylinder or rebuild it........i have put a very small amount of brake fulid in resevoir...can you rebuild without buying a hone?thanks in advance
Re: rear brake troubles-diagnose [Re: coup] #1027321 04/27/11 08:41 PM
timd75 Offline
if you put a clamp on the shoes to stop them from pushing outward, you can have someone step on brakes to check for leaks. I would clean everything up real good first. I have never rebuilt cylinders. I think paying for them is easier. Plus if it still leaks, you'll have to buy one anyway. I like new with warranty, but don't know about anybody else.
99 Sportage 2Dr, 1.5" body lift, 30x9.50 Cooper M/T's, high lift, CB, custom bumpers, Warn manual hubs, Tom Tom GPS, snorkel.
99 Jeep Cherokee 3" lift, 31" mud terrains
Re: rear brake troubles-diagnose [Re: coup] #1027322 04/28/11 12:44 AM
bombardj1 Offline
clean the area with brake cleaner s;ip the drum back on pump the breaks lots and lots on times the remove the drump again and check for leaks, have you had a low level of brake fld ? if not I would not think they are leaking, they could be sticking, in that case I would just buy new ones , replace both sides not just one
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: rear brake troubles-diagnose [Re: bombardj1] #1027323 04/28/11 04:08 PM
londart Offline
just replaced min....o'reilleys sells new ones for $11.99,autozone for $13.99 and found them @ a local parts store that specializes in imports that had them next forning for $8 a piece...for those prices with a warranty i wouldnt mess with rebuilding them
Lonnie
Auto Parts Professional
95 sportage sold but not forgotten
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5994 MB (Peak: 0.6551 MB) Data Comp: Off Server Time: 2026-07-09 17:11:24 UTC
