Keyless Entry Acting Up #1027382 04/28/11 08:27 PM
thatsnowinnebago Offline OP
My keyless entry system just starting having some issues. Sometimes when I go to unlock the doors they'll unlock for a second and then immediately relock themselves. Other times it will happily unlock the driver's door but then it will do the crazy unlock/lock thing when I hit the button again to open the rest of the doors. The fob always locks the doors though. I replaced the battery in the remote and its still having that same problem. This problem isn't described in the FSM so I'm hoping someone here has an idea.
Re: Keyless Entry Acting Up [Re: thatsnowinnebago] #1027383 04/28/11 09:08 PM
hazy_daze Offline
One of the actuators is sticking. Remove the door panels and watch them work while cycling the locks. The culprit should make itself apparent. Clean and lubricate with some white lithium or similar.
Re: Keyless Entry Acting Up [Re: hazy_daze] #1027384 04/28/11 09:43 PM
Scottie2113 Offline
there is a sensor mechanism in the driver door actuator that is pushing past itself, replace the driver door actuator and problem solved.
or you can snip the sensor wire in the driver door actuator and it won't lock the doors when turning key in the keyhole, but everything else will work. be careful prying apart the actuator......junk yards are good place to get a good actuator.
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: Keyless Entry Acting Up [Re: Scottie2113] #1027385 04/29/11 12:36 AM
Scottie is the rightest. The actuator wears over a jillion cycles, and the lock everything switch in the actuator that is supposed to trip all of the lock acutators is tripped at actuator rest position. It starts with exactly the behavior you describe, and ends up with the lock actuator in constant lock and even with the key, it is very difficult to unlock as you are fighting the actuator solenoid force. A temp "fix" until you can get at it is to pull the fuse for the pdl.
Re: Keyless Entry Acting Up [Re: fasteddy] #1027386 04/29/11 04:23 PM
ryany Offline
X2 on Scottie's info.
Someone on this forum has repaired their PDL solenoid before and posted about it, so if you feel like searching for it and you're fairly mechanically and creatively inclined, that's another option. IIRC, it involved disassembling the solenoid and fabricating some sort of stopper to prevent the solenoid from traveling too far.
95 Montero SR
Re: Keyless Entry Acting Up [Re: ryany] #1027387 04/29/11 05:25 PM
OK cool, thanks everyone. Looks like I've got a little project to do <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6138 MB (Peak: 0.6842 MB) Data Comp: Off Server Time: 2026-06-10 06:27:12 UTC
