1988 Pickup 22RE Remove Starter #1027388 04/28/11 09:31 PM
Y
yotadiehard Offline OP
I was having issues with my starter clicking and seemed to be pulling extra voltage(battery post burnt). Was going to take it off & rebuild it but could not figure out how to get the two bolts off. (Ticks me off to admit defeat). Decided to take it to the shop. Cleaned the cable ends and re-connected the cables. It now starts without a problem. Any ideas on what happened? Also how do you remove it for future reference if it happens again?
Re: 1988 Pickup 22RE Remove Starter [Re: yotadiehard] #1027389 04/28/11 09:49 PM
4Crawler Offline
Some tips below:
- http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
With IFS, best bet is a long extension with the ratchet out in from of the a-arms to give you a straight shot at the bolt/nut.
Re: 1988 Pickup 22RE Remove Starter [Re: 4Crawler] #1027390 04/29/11 01:30 AM
kewlynx Offline
x 2 Don't forget to disconnect your battery FIRST, or you'll be in for a rude and unsafe awakening.
**ubi apis- ibi salus**
Re: 1988 Pickup 22RE Remove Starter [Re: yotadiehard] #1027391 04/29/11 03:45 AM
OOP'S Offline
They were not making a good conection, that is why they were burnt. 12 volts is 12 volts it cannot pull more then that.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6035 MB (Peak: 0.6594 MB) Data Comp: Off Server Time: 2026-06-21 01:28:39 UTC
