OBA-York 210 compressor W/ Pics #1027524 05/03/11 02:59 AM
89montero Offline OP
Have 2 York compressors in my parts pile for on-board air. Both are the large, 210 model, verified by checking the end of the shaft. Only difference is that they have different heads and hose connectors. The one on the left was already being used for OBA on the donor truck(say's FoMoCo on the tag) and the one on the right(Says Motorcraft on the tag) was already unhooked when it was pulled from the vehicle so I'm not sure what they used it for.
basically I'm wondering if one is better than the other or if they just changed the shape over the years and it doesn't matter.
1989 Montero 4dr V6 3.0l
Re: OBA-York 210 compressor W/ Pics [Re: 89montero] #1027525 05/03/11 07:46 AM
They should be the same, Nice Score dude! I hope to hook up my truck with one some day. I've got a few friends with them and they can run air tools right off the compressor and airng up tires is FAST <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: OBA-York 210 compressor W/ Pics [Re: TOASTY] #1027526 05/03/11 04:10 PM
the bodies are identical just wondering why they have slightly different heads and if one design is better than the other. They are both the "long stroke", 210 model.
Re: OBA-York 210 compressor W/ Pics [Re: 89montero] #1027527 05/03/11 04:37 PM
RECON45 Offline
Looks like it is just different to accomidate different fitting for whatever vehicle they came off of. I would pick which one you like better and go with it.
Re: OBA-York 210 compressor W/ Pics [Re: 89montero] #1027528 05/03/11 07:56 PM
Pete_D Offline
If you can smell the wood burning it's because you got me thinking...........
I believe the Fomoco is going to be your OE unit and the Motorcraft is/was a new replacement part (not rebuilt or reman) for the Ford line. The MoCraft probably addresses a concern that they might of had and changed to update. If I remember right I think there was a big difference at the time of the warranty for the part. On some Motorcraft parts Ford used to pay a bonus if they were sold as they commanded a higher price for perceived great value/service.
I know they gave a $150 pop for a MoCraft engine sale so some of the MoCraft line had spiffs available.
3=(PI.98 SWB 2.8TD-TH92.LWB 2.8TD)Red90 SWB.V6/bal,forged pistons,bore/95SR lkr&spr/2 bouncies/(ARB.w/Gorilla 12K winch/new stg gear/stg&sus/CJ side mirr/cust tow rec/01 SR wh w/Mich 265-70-16LTX/Rancho5000's/Candy Apple/rock crawlers/Hellas/KC's
Re: OBA-York 210 compressor W/ Pics [Re: Pete_D] #1027529 05/05/11 01:41 AM
MainstreaM Offline
You can get bolt on outlet blocks drilled for NPT fittings for the one on the right.
Kane
89 Conquest - 2.4 DOHC <--Thats right DOHC Turbo and MPI.
87 Starion flatsider - under restoration
87 Conquest - Saved from the crusher
86 Conquest - Another crusher rescue
88 Conquest - Previous owner abandoned project
87 Raider - under construction
86 Conquest - DD
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6102 MB (Peak: 0.6810 MB) Data Comp: Off Server Time: 2026-05-29 22:33:53 UTC
