3vze Timing Belt recommendations, etc.
#1027748
05/06/11 03:09 AM
Just bought my sister's truck - was my Dad's, new off the sales floor. 1994 2wd extra cab v6 5speed. Only has 145k on it :-) I need to replace the timing belt. Last time I know it was done was at 60k. What brands/from where to purchase? What else should I replace while I'm there?
Also, are there still headers made for these motors? I haven't had time to look into it more, but I think I have an exhaust leak on the drivers side.
Thanks in advance!
1986 Pickup extracab longbed "Woody edition" SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD" 94 2wd v6 extracab 04 Outback Wagon- wife's/family car
Re: 3vze Timing Belt recommendations, etc.
[Re: Elbow_Greese]
#1027749
05/06/11 08:22 PM
If you are going that far into it, I would also do Tension pulley, and idler pully. I went toyota for the belt, but pullies I went to parssdinosaur Upper Idler Tension Pulley, bearing only..
[Re: Staceman]
#1027750
05/06/11 10:30 PM
"Serenity through Sobriety"
[Re: OOP'S]
#1027751
05/08/11 04:48 PM
I would do everything mentioned above, (belt, tensioner bearings, water pump) as well as thermostat and gasket(s), change the drive belts, and check everything else over (radiator, etc.)...
89 4Runner 3" BL, M/T locks, 33"bfg mt, bilstein, Kayline, tubebumper, toyotafiberglass panels TBI: Elocker,3.4 w/ORS,b+b,S2Sstg2cams,arias pistons,P+P intake,TRDs/c,URDpullies+7th,downey headers,MAPECU2,WEGO WB, SupraMAF,walboro255,stg4clutch, EPaOo2 sim
