Header collector outlet size? 2.6 motor #1027947 05/10/11 04:06 AM
theheep Offline OP
Im having a hard time finding anywhere around here that will build me an exhaust around here without a cat in it and the jerk wad that owned the truck before me cut off the exhaust at the header and shrank it down to what looks like scooter sized exhaust piping and ran a cherry bomb glass pack. Needless to say it sounds like [censored]! I am gonna use a flowmaster 40 series or a Hushpower like in my old Jeep cause they are slim and really easy to tuck up and out of the way. What size is the collector outlet and did you guys use a flex connector? Im not sure how much these engines flex and I dont want to break the new exhaust by cheaping out. Thanks.
Re: Header collector outlet size? 2.6 motor [Re: theheep] #1027948 05/10/11 04:09 AM
The 2.6 likes back pressure. Seriously. Don't use big pipe.
Re: Header collector outlet size? 2.6 motor [Re: JohnnyBfromPeoria] #1027949 05/10/11 04:36 AM
theheep Offline OP
You thinking two and a quarter or two inch? And I have since decided to use a high flow cat after research here and low gas mileage because the 02 sensors dont read right becasue they dont heat up without the back pressure not running a cat.
Re: Header collector outlet size? 2.6 motor [Re: theheep] #1027950 05/10/11 09:31 AM
With a stock 2.6 a 2" exhaust is good. You do not want to be smaller than that. If it is made at a muffler shop with thick tube and crimped down bends you might want to run a 2? tube.
Re: Header collector outlet size? 2.6 motor [Re: OldColt] #1027951 05/11/11 01:06 AM
theheep Offline OP
Yeah im supposed to have one made Monday and I think with the cat and muffler, Im gonna stick with 2.25 unless someone else has had better luck with 2.5?? Please feel free to offer opinions.
Re: Header collector outlet size? 2.6 motor [Re: theheep] #1027952 05/11/11 02:39 AM
Kevin C Offline
2.5 seems like overkill for a NA motor.
Re: Header collector outlet size? 2.6 motor [Re: Kevin C] #1027953 05/11/11 04:01 AM
theheep Offline OP
thats what i thought but wanted to make sure. thanks for the input. i wanna really maintain as much torque as possible and too little backpressure will decrease it.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6192 MB (Peak: 0.6934 MB) Data Comp: Off Server Time: 2026-07-15 07:11:50 UTC
