22re Timing Chain Tensioner...I think #1027954 05/10/11 04:36 AM
Brimt Offline OP
When my 22re warms up it sounds like the timing chain is scraping against the timing cover. I have replaced the chain, guides, and tensioner twice in the last year. Both kits came from my local Advance Auto Parts store. It seems like the tensioner just isnt doing its job once the engine warms up. Should i have just ordered the tensioner and chain from Toyota? Could it just be that the tensioners and chains from Advance just are cheap junk? I feel like i shouldve just ordered them from Toyota. Is there a big difference in factory toyota tensioners and aftermarket ones? Thanks for the help!!
Big T
Re: 22re Timing Chain Tensioner...I think [Re: Brimt] #1027955 05/10/11 06:09 AM
kewlynx Offline
Sure you've got all the TC cover bolts in the right place? Long one in a short spot will get hit. Any signs of chain wear on the cover?
**ubi apis- ibi salus**
Re: 22re Timing Chain Tensioner...I think [Re: Brimt] #1027956 05/10/11 01:18 PM
stock87 Offline
Are you using a torque wrench when installing the parts? Ted said that it doesn't take a ton of force to distort the tensioner body and lock it up so it can't to it's job. It's a very low torque spec IIRC.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: 22re Timing Chain Tensioner...I think [Re: kewlynx] #1027957 05/10/11 10:10 PM
Brimt Offline OP
Yeah i did use a torque wrench installing the bolts. THe tensioner bolts are only supposed to be around 12 lbs. Also, i thought at first that i may have had one of the bolts for the oil pump in the wrong place, but i went back and checked and they're all in the right spots. There is a little wear on the timing cover, but its where the guides broke the first time.
Big T
Re: 22re Timing Chain Tensioner...I think [Re: Brimt] #1027958 05/10/11 11:29 PM
engnbldr Offline
>>>*Be sure and check the oil pan for debris. When one of these assemblies fails there is normally a lot of material in the pan, that can get pounded into very small particles and it will end up inside the tensioner and cause it to be sticky.
Another possible is lower than normal oil pressure, also but debris/silicone/swarf is the #1 cause of tensioner failure....*EB
*Beats the he** outa me!....*LOL**...
Re: 22re Timing Chain Tensioner...I think [Re: engnbldr] #1027959 05/11/11 03:18 AM
Brimt Offline OP
My O.P. is around 60 psi when cold, but it drops to about 20 psi after it warms up.
Big T
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6109 MB (Peak: 0.6823 MB) Data Comp: Off Server Time: 2026-06-07 10:34:56 UTC
