98 2.5 fixes. Phnx AZ Salvage info? #1028021 05/11/11 12:47 AM
O
OneTime Offline OP
I need to attended to some issues with my 98. Instead of paying stealership prices im going to try and go the salavage yard route for my first time. Two major issues: First the hatch to my rear door cracked. Its the inside piece you squueze direclty bheind the MITSUBISHI letters on the rear door handle/ license plate holder. Has anyone ever had the problem? Can you fix it with just switching out the entire unit?
Second is a short in my drivers seat. It wont move back and forth. Can I replace the motor or do I need to replace the whole seat?
And last any idea where I can find said parts in the Phnx area?
98 Gen 2.5 w/ winter package & 31x10 BFG ATs.
Re: 98 2.5 fixes. Phnx AZ Salvage info? [Re: OneTime] #1028022 05/11/11 01:32 AM
ryany Offline
There's a plastic lever that breaks on the rear door handle - not uncommon. You'll just need to replace your door handle assembly - it comes off with a couple of 10mm nuts once you have the inside trim panel and plastic vapor barrier out of the way.
Your seat issue needs some diagnosis before you waste any money just throwing parts at it - download the FSM wiring diagrams first (so you know which wires to be checking), then you'll first want to check to see if you have power at the seat switch. If you have power there then check to see if there's power getting to the motor. Your problem could be a broken or cut wire, a bad connection at a wiring connector, a bad seat switch, or a bad seat motor, but find the cause before you replace any parts.
95 Montero SR
Re: 98 2.5 fixes. Phnx AZ Salvage info? [Re: OneTime] #1028023 05/11/11 02:56 AM
monte3 Offline
Keith, I had the same issue(s) on Gen 2 and 2.5's.
I tried to repair the plastic handle, but it didn't last too long. I decided to get a new one at the <img src="/forums/images/graemlins/evil.gif" alt="" /> dealer, around $50.
The seat switch could just need a good cleaning of the contacts.
98 Gen 2.5
05 Pontiac GTO
91 Corvette ZR-1
2011 Kia Sorento (wifey mobile)
Clarkdale, AZ
Re: 98 2.5 fixes. Phnx AZ Salvage info? [Re: ryany] #1028024 05/11/11 03:58 AM
theheep Offline
Damn, power seats!! I dont even have power steering right now LOL!
Re: 98 2.5 fixes. Phnx AZ Salvage info? [Re: theheep] #1028025 05/11/11 04:57 AM
4xmonty Offline
check real good under the seat I had a wrench get jammed under
mine that keep it from moving
Russ
GETTIN OLD THATS EARNED
Happy trails to you
(1)98 Montero SR RB Rock Crawlers BFG 33s Rancho 9000's OME Med coils rear
(2)95 4Runner All Pro Nerf bars BFG 32s
ARB bull bar
Downey 2" rear coils Downey headers
(3) 90 Montero LWB 3.0 auto
(4) 98 Kawi GPZ1100
Re: 98 2.5 fixes. Phnx AZ Salvage info? [Re: 4xmonty] #1028026 05/11/11 07:34 AM
Yeah the rear door handle is worth buying from the stealer, look up the part then put in the part number in mitsubishiparts.net to make sure your dealer of choice is giving you a good deal. Like Monte3 said i think i paid 50 for mine and you get the whole assembly minus the cover. The seat might just have dirty contacts in the switches. Move the switches back and forth a bunch and see if it moves and if it does take it apart and clean it with electrical cleaner and steel wool.
Re: 98 2.5 fixes. Phnx AZ Salvage info? [Re: OneTime] #1028027 05/11/11 08:29 AM
Dylan Offline
What they said <img src="/forums/images/graemlins/kewl.gif" alt="" />
BUT.... if anyone knows of any Gen2's in a yard around Phoenix or somewhat further out, please don't be afraid to speak up! Just Trucks still hasn't moved the one they have in reserve out to the line and I need some little things I am not paying dealer prices for and I haven't seen one anywhere else....
'95 Montero SR 3.5L, Trail Gear Sliders, Rugged Ridge XHD Front Bumper, 33x12.5 Duratracs, much more in the works....
Re: 98 2.5 fixes. Phnx AZ Salvage info? [Re: Dylan] #1028028 05/11/11 01:35 PM
haztoys Offline
Az Crew mountain division checking in... <img src="/forums/images/graemlins/patriot.gif" alt="" />
Up the hill here theres a 95 SR and 92 (92 is a Gen2 right ...???)
95 SR is black and silver outside brown inside ...Not got to the 92 yet but the J-yard data base says its there ...Two swb 4cyl each white... one grey inside ..One blue inside ..
I "should" be plundering the 95 this week end if no rain ...And yes the air lockers gone ..Its at my house for $110.00... <img src="/forums/images/graemlins/nana.gif" alt="" />.... <img src="/forums/images/graemlins/smile.gif" alt="" />
David
Hazardous Toys inc
Re: 98 2.5 fixes. Phnx AZ Salvage info? [Re: haztoys] #1028029 05/11/11 05:12 PM
monte3 Offline
David,
Is this yard open on Sunday's?
I might get over to your side of the mountain this weekend.
Thanks, Paul
98 Gen 2.5
05 Pontiac GTO
91 Corvette ZR-1
Clarkdale, AZ
Re: 98 2.5 fixes. Phnx AZ Salvage info? [Re: haztoys] #1028030 05/11/11 09:14 PM
Dylan Offline
Sounds like that one could have what I need, but I have a whole list, and I don't think I can get up that way this weekend. I too would like to know if they are open on Sunday, because if I can go up, that would be when I could. If I can't go, and anyone wants my list, talk with me and we'll see if we can't work things out....
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6382 MB (Peak: 0.7628 MB) Data Comp: Off Server Time: 2026-11-03 13:37:18 UTC
