Page 2 of 3 1 2 3
Re: First Post - Exploded Axle Fun Times, what to swap? [Re: off-roader] #1028091 05/13/11 01:21 AM
Lovine Offline OP
Just curious, were you running a rear anti-sway bar and what shocks were on the truck when the breakage occured? ( just curious about a theory I've had for a long time...
Good question Justice... It's kinda hard to tell but the 2nd pic has what looks like the antisway bar but I could be wrong about that...
I believe the rear sway bar is still installed, and if I'm not mistaken it is running a new set of Rancho shocks..
1989 Dodge Raider 3.0L V6
1987 Suzuki Samurai 1.6L 16v
Re: First Post - Exploded Axle Fun Times, what to swap? [Re: KrzyDav] #1028092 05/13/11 03:34 AM
justice Offline
make it even easier,,,
92-94 Gen2 2 LS,,,( not the 92-93 SR . It has 4.88 gears and then you'll have to swap front gears).
3" wider
Disc brakes
LSD , 9" ring, 4.63
bolts right in and you don't need to mess with adding compressor and wiring and switch.
For a SWB all you need is the LSD, unless your doing serious rock crawling.
There's still a 95 SR sitting in a yard near me with fairly low miles on it's locker rear. San Luis Auto Salvage, SLO Town, CA. they'll ship.
I don't agree. Why would he want to swap both the front and rear diffs instead of just the rear? I say go with the 95-6 axle. That way you dont have to mess with the front..swapping out the front diff is a PITA ..plus the 92-93 front diff is smaller, his axle shafts wont fit and it has no ARB available for it.
Wiring of the locker is easy with the stock pump, just a switch on and off. Get the pump if you can.
Re: First Post - Exploded Axle Fun Times, what to swap? [Re: Lovine] #1028093 05/13/11 03:48 AM
justice Offline
Not saying this is what caused the breakage, but I recommend swapping in stock length shocks (i.e. KYB)...Anything longer and you will twist the axle housing like a torsion bar when you articulate...so one of two things will happen..one of the trailing arms will snap, or the axle housing will break open at the same weld...
Re: First Post - Exploded Axle Fun Times, what to swap? [Re: justice] #1028094 05/13/11 05:00 AM
ryany Offline
Wow, I saw the broken axle pics and I thought I had mistakenly logged onto the Jeep forum. <img src="/forums/images/graemlins/lol.gif" alt="" />
95 Montero SR
Re: First Post - Exploded Axle Fun Times, what to swap? [Re: justice] #1028095 05/13/11 05:15 AM
Kevin C Offline
Just curious, were you running a rear anti-sway bar and what shocks were on the truck when the breakage occurred? ( just curious about a theory I've had for a long time...
I think I know where you are going with that. The more flex you get the greater the torque stress on the axle. As the bushing in the arm start to max out on their flex, the torque force on the housing goes up very quickly with any extra travel. Basically, there is a limit to how far you can have one wheel go up with the other dropping before you start to bind up the rear suspension.
Going past the binding point puts a lot of stress in the axle. Add in the torque from climbing and the housing fails.
Two solutions.
1: Limit the axle travel to stock.
2: Develop control arms with more flex.
3: Beef up all the parts so they dont crack when overloaded.
Re: First Post - Exploded Axle Fun Times, what to swap? [Re: justice] #1028096 05/13/11 05:45 AM
KrzyDav Offline
Justice , let me try to clarify,,,, What I'm trying to say, if he gets a 92-93 axle 'not' to get a locker from those years cause it will not match his front diff ratio. Make sure it's from an LS with 4.63 and make sure it has the LSD.
If he wants a locker, yes, that 96 axle is the way to go.
( although I thought all the 3.5 dohc SR axles were the 9 1/2" 94-96,,,? what's the differences in those years?).
dave h.
Re: First Post - Exploded Axle Fun Times, what to swap? [Re: Lovine] #1028097 05/13/11 05:58 AM
KrzyDav Offline
I don't think there is anything to worry about putting the ABS SR axle into your Gen 1,,,you just don't connect any wires up.
The yard in SLO Town is closed on Sat. It is next to the airport. Everthing was still there 3 weeks ago. It's in there cause of blown headgaskets. The axle has 150 K on it.
I'm pretty sure it's a '95 and not a '96 ( I don't see any difference.)
Re: First Post - Exploded Axle Fun Times, what to swap? [Re: KrzyDav] #1028098 05/13/11 02:24 PM
justice Offline
OK I'm tracking with you now Krzy...I do agree then <img src="/forums/images/graemlins/lol.gif" alt="" />..but why not add beef? The reason I say stay away from 94 to early 95 is due to the larger diff flange that causes one to have to modify the drive shaft in order for it to fit (see swap thread link in criticle threads post).
Re: First Post - Exploded Axle Fun Times, what to swap? [Re: Kevin C] #1028099 05/13/11 02:35 PM
justice Offline
Two solutions.
Exactly..With the coil spring trailing arm suspension this is a weak point. Mitsu addressed it with the gen 2 by beefing up the trailing arms in a couple spots..highly recommend that gen 1 guys that wheel (even moderate wheeling) swap to the the gen 2 arms (direct bolt on).
In my opinion longer shocks really add to the problem since you will over articulate..if I'm not mistaken both Lloydd and ray had longer than stock shocks when they both cracked their axle housings on the Con...Just saying..
I haven't seen a gen 2 break an arm or housing yet, not even the AZ crew or Carlos or my old 95 all acid tested..Although I heard of aussies breaking the housing (rarely)...
Re: First Post - Exploded Axle Fun Times, what to swap? [Re: justice] #1028100 05/13/11 07:16 PM
LandRaider Offline
Trailing arms?? What are those? <img src="/forums/images/graemlins/lol.gif" alt="" />
Kidding aside, that is some serious, and uncommon mitsu carnage!
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6524 MB (Peak: 0.7780 MB) Data Comp: Off Server Time: 2026-10-21 20:43:58 UTC
