Page 3 of 3 1 2 3
Re: First Post - Exploded Axle Fun Times, what to swap? [Re: justice] #1028101 05/13/11 07:32 PM
3: Beef up all the parts so they dont crack when overloaded.
I haven't seen a gen 2 break an arm or housing yet, not even the AZ crew or Carlos or my old 95 all acid tested..Although I heard of aussies breaking the housing (rarely)... [/quote]
Agreed, making an SR rear end upgrade all the more attractive to those who wheel Gen I's...
One question I had is how often and how hard John wheeled his Montero? Regardless, to be safe if you wheel your Montero then it's HIGHLY recommended you swap in a Gen II rear end.
Re: First Post - Exploded Axle Fun Times, what to swap? [Re: off-roader] #1028102 05/14/11 12:19 AM
Lovine Offline OP
Thanks for all the tips guys, I ended up getting a 91 Montero V6 rear axle assy at a junkyard in Hollister for 2 benjamins. I hope it fits. The 96SR axles (what I could find) cost more than 5 bones, and I didn't have the luxury of time (and space) to wait for a good deal to show up.
Other guys I talked to offline spoke about welding a truss bar to the axle, is this also a good option aside from reinforcing the trailing arms and swapping back stock spec shocks?
I also have an 87 Suzuki Samurai, which will probably get the bigger share of (destructive) wheeling. I'll try not to break anything next time. <img src="/forums/images/graemlins/cheers.gif" alt="" />
1989 Dodge Raider 3.0L V6
1987 Suzuki Samurai 1.6L 16v
Re: First Post - Exploded Axle Fun Times, what to swap? [Re: Lovine] #1028103 05/14/11 12:25 AM
KrzyDav Offline
I know I'm kinda out of the way,,,I just don't want to see another Montero going to china to melt.
The axle in SLO would probably be gotten for $300.
dave h.
Re: First Post - Exploded Axle Fun Times, what to swap? [Re: Lovine] #1028104 05/14/11 01:21 AM
What I've heard most have done overseas is reinforce the axle shaft housing with some kind of sleeve.
There's a write-up I put together on re-enforcing your trailing arms or alternatively you can put on gen II trailing arms which are beefier and a direct bolt in.
Re: First Post - Exploded Axle Fun Times, what to swap? [Re: off-roader] #1028105 05/14/11 01:27 AM
StockRaider Offline
I caught my LWBs stock axle before it broke, but the crack was in the same spot on the opposite side, I have a feeling the welds on these axles were a bit hit or miss in 89... My Raiders axle was and still is perfect. I wouldn't be scared to wheel the Montero harder than the sami at all, that axle was probably just one of the rare bad ones. If you wanted a little bit of security, weld some horizontal slats across those weld spots?
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: First Post - Exploded Axle Fun Times, what to swap? [Re: StockRaider] #1028106 05/14/11 06:08 AM
justice Offline
Just do it..
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 7.709s Queries: 16 (0.006s) Memory: 0.6228 MB (Peak: 0.7254 MB) Data Comp: Off Server Time: 2026-10-24 03:20:56 UTC
