3.8 Taurus/etc. electric fan FAQ? #1028696 05/17/11 09:38 PM
W
WagonMaster Offline OP
Is there a colluded collection of 3.8 electric fan info/wiring, perhaps in the FAQ?
I looked, but couldn't find one.
If there isn't, I'd be happy to collude all the info, if somebody will tell me what format to use.
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5
1992 Chrysler LeBaron Convertible: 3.0/A
1994 GMC Safari: 4.3/A
Re: 3.8 Taurus/etc. electric fan FAQ? [Re: WagonMaster] #1028697 05/17/11 09:55 PM
Go ahead and put them into this thread and I'll add it to the FAQ. FWIW, I just did a search for Taurus for the past 5 years and came up with 57 hits. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 3.8 Taurus/etc. electric fan FAQ? [Re: off-roader] #1028698 05/17/11 10:44 PM
W
Should I just copy/paste the relevant info into a single long post? I'd love to see the various wiring diagrams as well, if somebody is willing to host them.
Re: 3.8 Taurus/etc. electric fan FAQ? [Re: WagonMaster] #1028699 05/18/11 12:40 AM
L
LeeForget Offline
~88 Raider 2.6L 5 speed
~35"x14.5"r15
~SOA(Spring Over Axle)
~TT(Torsion Twist)
~SBL(Sloped body lift)
Re: 3.8 Taurus/etc. electric fan FAQ? [Re: LeeForget] #1028700 05/18/11 01:40 AM
Grasscat Offline
The Taurus fan will fit on the Gen I with very few mods, but will not fit on the Gen II or later. Not enough space between the radiator and the fan blade bracket.
Check this post.
Michael j
TreadLightly! Trainer
Re: 3.8 Taurus/etc. electric fan FAQ? [Re: Grasscat] #1028701 05/18/11 08:35 PM
W
In doing a bit of research on the web, I've found out a few things about the "3.8 Taurus" fan.
It seems that the same fan "concept" was used in the Taurus/Sable, the T-Bird, the Cougar/XR7, the Mark VIII, and the Continental. There may even be others I haven't found yet.
The fan was used with the 3.8, 3.8 SC, and the 4.6, and came in MANY motor/blade/diameter/CFM combinations.
The Amp requirements (start-up on High) are anywhere from 40 to 100, depending on which website you believe and which fan you have.
Interestingly, according to AllData (for the 1995 vehicle year), the "smallest" of the fans (Taurus/Sable, 3.8) run on a 50 amp fuse, while the T-Bird/Cougar/XR7/Continental (3.8, 3.8SC, 4.6) all use a 60 amp fuse, and the big boy ("strongest" motor, largest diameter, most CFM) in the Mark VIII only uses a 40 amp fuse.
Looks like this will make for some interesting research.
I will collude as much of the info together as I can, and ask that you guys amend it with information that I miss.
Re: 3.8 Taurus/etc. electric fan FAQ? [Re: WagonMaster] #1028702 05/19/11 07:41 AM
W
OK, here we go.
I'll be uploading this about 20 minutes at a time, since that's about all the longer I can sit at a time.
It seems that the "Taurus 3.8" fan came in many varieties, and the motors from several manufacturers over the years, with different specs (speed and efficiency).
The 94-97 Thunderbird and Cougar XR7: All engines (3.8, 3.8SC, 4.6), used a 60 amp fuse and dual relays to power a 16" fan with a low and high setting. It seems to be using a blade configuration that is different than the Taurus (closer to, but different than, the Mark 8) but a motor that is one of the various Taurus units.
The 90-95 Taurus and Sable, and 90-94 Continental: 3.8 engine, used a 50 amp fuse and dual relays to power a 16" fan with a low and high setting. This configuration seems to be running about 26 amps on low (32 at start) and 29 amps on high (45 at start)...OR...running about 34 amps on high at 3,750 CFM. Or 3,800 CFM. Or 4,000 CFM. Or 4,500 CHM. Or 4,800 CFM. Or 3,500 CFM.
However, some sources claim that it takes 100 amps to start the high speed.
It seems that this unit runs about 2,500 CFM on the low speed. Or 2,900 CFM.
The 93-96 Mark 8: All engines (4.6), used a 40 amp fuse and a single relay to power an 18" fan with a low and high setting. This one is interesting, since it uses the smallest amp fuse, but has the most powerful motor. It used the high speed with a variable control relay module (VCRM) to dynamically vary the speed. This would be consistent with the idea that the Mark 8 fan has a stronger motor and larger diameter, but because of the noise-reducing blade pitch, has the same CFM as other fan combinations.
This configuration seems to be running about 28 amps on low (40 at start) and 35 amps on high (53 at start)....OR...running about 28 amps on high at 4,300 CFM. Or 4,500 CFM. Or 4,800 CFM. Or 5,000 CFM.
Because it uses a variable relay, the 53 amp high start would never take place, as the fan would already be running. Perhaps that's how they can get away with the 40 amp fuse. And perhaps a DCC would allow for the same.
ôI just laugh at myself now when I see how seamlessly the DC controller works. Not only is the control much better (on mine within 2 or 3 degrees), the fans don't work near as hard. They ease on as the current ramps up, so I don't have the short-term 80-90A hitting the system with both fans coming on full. In fact, I went back and installled the indicator light Brian sells because I couldn't even tell they were coming on at all so smooth and quiet is the operation. Now I'm mesmerized watching the light change colors from green to yellow to orange to red as the fans speed up and down keeping the engine cool. Pretty amazing stuff. And, it saves wear and tear on both alternator and the fan motors. It really is a better mousetrap with no downside.ö
Many folks talk about the need for an upgraded alternator, especially with the 100 amp start-up story. I'm not the smartest guy in town, but it seems to me that the 100 amps (if it even actually needs that) could come from the battery, since it's only for a moment, and the steady running high fan would only draw a constant 35 amps. Does an additional 35 amps MAX (that's for the high speed) really require an alternator upgrade?
Re: 3.8 Taurus/etc. electric fan FAQ? [Re: WagonMaster] #1028703 05/19/11 04:48 PM
Grasscat Offline
I found the same results when I had the DCC controller install on my Gen I.
I never seen or heard it run at full speed while it was installed, it always started very slowly and ramped up when needed. This could have been because I was running a three core radiator.
I did not have the light kit, but did install a switch so I could turn it on or off from the dash. Comes in handy when forging a water crossing.
Good job on you research and write-up. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Michael j
Re: 3.8 Taurus/etc. electric fan FAQ? [Re: Grasscat] #1028704 05/20/11 02:41 AM
What is 'collude'?
Collate?? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: 3.8 Taurus/etc. electric fan FAQ? [Re: rxinhed] #1028705 05/20/11 05:25 AM
Pete_D Offline
Well - it is a word - collusion
Guess someone could be known as the "collude dude" <img src="/forums/images/graemlins/scared.gif" alt="" />
colÀlude (k-ld) <img src="/forums/images/graemlins/evil.gif" alt="" />
intr.v. colÀludÀed, colÀludÀing, colÀludes
To act together secretly to achieve a fraudulent, illegal, or deceitful purpose; conspire.
3=(PI.98 SWB 2.8TD-TH92.LWB 2.8TD)Red90 SWB.V6/bal,forged pistons,bore/95SR lkr&spr/2 bouncies/(ARB.w/Gorilla 12K winch/new stg gear/stg&sus/CJ side mirr/cust tow rec/01 SR wh w/Mich 265-70-16LTX/Rancho5000's/Candy Apple/rock crawlers/Hellas/KC's
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6470 MB (Peak: 0.7765 MB) Data Comp: Off Server Time: 2026-05-29 19:55:16 UTC
