moon roof restoration (OE sunroof glass) #1028746 05/19/11 01:55 AM
CJM Offline OP
this would apply to ANY rare glass , not just the moon roof .....
so I have a couple of these for my Trekker . Both are ok , but have scratches on the glass ... So I decided to try "fix" the worst one ..
This one was from a unit I parted a few years back .. It was rolled , as you can see the deep scratches on the glass .
so first .. I put some tape on the back side , so I would know ware I'm working
then I brought out the DA and started to sand it with 220
it as far as I got today ..
83 Trekker SR5
NEW Trekker forum
Re: moon roof restoration (OE sunroof glass) [Re: CJM] #1028747 05/19/11 01:59 AM
kewlynx Offline
There's going to be a lot of folks who are going to love you for this one Corey. Moon glass is pretty rare anymore for Yotas.
**ubi apis- ibi salus**
Re: moon roof restoration (OE sunroof glass) [Re: kewlynx] #1028748 05/20/11 01:44 AM
CJM Offline OP
got a little bit more done today
wet sanded with 400G
wet sanded with 600G
wet sanded with 800G
and removed the tape
just need to polish to remove the haze
83 Trekker SR5
NEW Trekker forum
Re: moon roof restoration (OE sunroof glass) [Re: CJM] #1028749 05/21/11 12:36 AM
RatLabGuy Offline
HOLY CRAP.
I had no idea you could do that!
I mean, it does make sense now that I think about it... just never put 2+2...
Question Reality.
Re: moon roof restoration (OE sunroof glass) [Re: RatLabGuy] #1028750 05/21/11 01:54 AM
CJM Offline OP
I spent a few more hours sanding .. and polishing .. 6 hours total so far (wow a lot of time!!)
reflection is awesome , but there are still some haze spots .. captured pretty good on the camera , but you really have to "look" to see them .. and I think on top of the roof , no one would ever notice
overall , I'm pretty happy .. no more scratches , which were visable from far with the roof open , and also visable from looking inside up at the roof .. you no longer can see them , and the minimal haze , is not visable either from the inside
83 Trekker SR5
NEW Trekker forum
Re: moon roof restoration (OE sunroof glass) [Re: CJM] #1028751 05/28/11 06:53 AM
F
flyinhawaiian Offline
nice job, you may have to go up to 1500 and higher to get the haze out... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: moon roof restoration (OE sunroof glass) [Re: flyinhawaiian] #1028752 06/09/11 01:18 AM
matts Offline
All this gets me to wondering, what does it take to install a "moon roof" in a second or third generation p/u that never had one in the first place? Assuming you could find a donor with all the right parts. -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: moon roof restoration (OE sunroof glass) [Re: matts] #1028753 06/09/11 01:26 AM
kewlynx Offline
We'll find out when Corey puts it on the Trekker, I s'pose.
Def starts with a template and a sawzall. <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: moon roof restoration (OE sunroof glass) [Re: matts] #1028754 06/09/11 02:44 AM
4Crawler Offline
Might be easier to go with an aftermarket sun-roof kit. I put one in a VW pickup once, no0t too bad an install. Kit came with a 2-piece frame and template and it was pretty easy to cut out the sheet metal. Then drop the outer frame down in the hole with sealant around the rim, then the inner trim/frame up from below and tick in the headliner and it was done.
It seems the hard part with the factory moon roof is that is is pretty much built into the roof, so would be a lot harder to remove and then you would need to make a template and figure out how to get it re-installed.
Re: moon roof restoration (OE sunroof glass) [Re: 4Crawler] #1028755 06/10/11 01:48 AM
CJM Offline OP
doing a "factory" moon roof would require a whole roof section .. the factor moon roofs are rienforced , not like a "jobber" sun roof you just cut a hole .
this was the whole reason I "restored" my trekker cab .. because it had the factory moon roof .
anyways ..
I havent done anymore with the glass .. I'm just trying to get the trekker back together right now
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6405 MB (Peak: 0.7464 MB) Data Comp: Off Server Time: 2026-11-02 08:27:47 UTC
