Weber carb swap - accelerator cable issue #1029183 05/27/11 01:32 PM
Mudraider Offline OP
On the 88 SWB I just got, a Weber has been installed. It needs an engine swap, so I need to disconnennect it. The PO (or his mechanic) cut the original end off with taping, heat shrinking etc. Look at this; [img][image]http://i598.photobucket.com/albums/tt64/fastfoodvw/The%20Shogun/Shogunenginecompartment010.jpg[/img][/image]
You can see how frayed it is. When I disconnect it I'm worried it will just totally spread apart. Any ideas on an end for it?
Re: Weber carb swap - accelerator cable issue [Re: Mudraider] #1029184 05/28/11 06:32 AM
Skibane Offline
I'm not seeing a problem here...
If the cable becomes frayed after you disconnect it from the carb linkage, twist the frayed wires back together before re-threading it through the hole in the linkage bolt.
It don't have to be purdy - just functional!
The Redneck Special: 88 Ram 50 2WD XCab with 167K on the original 2.6L, 5-Sp, Weber 38DGS, Crane HI-6 with timing adjust, 4-for-$100 tires, Generac 4000EXL 4KW AC generator, Hampton Bay 12KBTU window air conditioner sticking through a hole hacked in the back of the cab...All it needs now is a gun rack...
Re: Weber carb swap - accelerator cable issue [Re: Skibane] #1029185 05/28/11 01:47 PM
LandRaider Offline
you could crimp them all together with a fishing leader crimp, or an electrical one, and then braze or solder them together, and then remove the crimp.
Re: Weber carb swap - accelerator cable issue [Re: Mudraider] #1029186 05/28/11 03:27 PM
sandhill_raider Offline
Had the same problem with mine. Did my best to twist back togther, souldered, rolled and tapped with hammer to get back to round. Had to drill out the pin slightly larger to feed back through, but it works.
1988 Dodge Raider, Clearwater, 33x12.5 Buckshots, RB 2" Lift, Weber, 2.6L rebuilt by me with a lot of help from you guys. Thanks!
www.cardomain.com/ride/2980730
Re: Weber carb swap - accelerator cable issue [Re: LandRaider] #1029187 05/29/11 03:24 AM
That's a great idea Curtis. Will do that tomorrow. Simple fix for an annoying problem. With the VW's there was all kinds of shorteners available, I don't know if they are even available anymore.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6071 MB (Peak: 0.6720 MB) Data Comp: Off Server Time: 2026-10-21 20:47:13 UTC
