Charge light and E-Brake light came on.... #1029198 05/28/11 06:59 AM
F
flyinhawaiian Offline OP
howzit, everyone. the other day both lights came on. yesterday, i used my truck and both lights were flickering?? not sure if it's a bad connection or a bad alternator? any ideas? i have a 1983 Yota 4x4 reg cab. Thanks. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Charge light and E-Brake light came on.... [Re: flyinhawaiian] #1029199 05/28/11 09:00 AM
Snowtoy Offline
The lights usually indicate a charging issue. If you have an amp meter you can check to see what the alternator is putting out at the battery, should be about 13-14 volts. You can also check the battery to see if you have been running off the alt or the battery. If the alternator isn't working the battery should be below 12volts.
If no amp meter, you can pull the alternator and have it checked for free at most parts stores. Be sure to disconnect the battery first, the alt cable that runs to the battery has power to it all the time.
Re: Charge light and E-Brake light came on.... [Re: flyinhawaiian] #1029200 05/30/11 02:05 AM
kewlynx Offline
x 2 per Snowtoy.
If your truck doesn't have the separate voltage regulator, then this:
http://www.4x4wire.com/toyota/maintenance/alternator_brushes/
Original alternator?
**ubi apis- ibi salus**
Re: Charge light and E-Brake light came on.... [Re: flyinhawaiian] #1029201 05/31/11 02:39 AM
Elbow_Greese Offline
I know it sounds weird, but check your brake fluid level.
I thought those lights both came on when the fluid level was low.
Just a thought.
Todd
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: Charge light and E-Brake light came on.... [Re: Elbow_Greese] #1029202 05/31/11 03:15 AM
kewlynx Offline
Ah yes; good remembering Todd; hope you're well! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Charge light and E-Brake light came on.... [Re: flyinhawaiian] #1029203 05/31/11 03:31 AM
Dandeman Offline
Toyota Moderator
If the brake fluid level is OK as Todd mentioned above, then it's probably the alternator.
The alternator "charge" and the "brake" lights are in an oddball circuit configuration in Toyotas.
Long story short, when there is no alternator output or, (if you have a 7.5 amp fuse labeled "chg" for "charge") if that fuse is blown, both lights will also come on.
Since your symptoms are intermittent flashing of both lights, (assuming brake fluid level OK) the next likely cause is the alternator slip ring brushes are on their last leg..
It's a fairly simple job the pull and replace the brushes as shown in kewlynx's link above...
Re: Charge light and E-Brake light came on.... [Re: Dandeman] #1029204 06/01/11 08:53 AM
F
thanks guys. Over the weekend i ran down to checkers and they did a free battery/alt check. turned out to be a bad alt. changed it all is good. wierd though how the e-brake light comes on. Aloha. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Charge light and E-Brake light came on.... [Re: flyinhawaiian] #1029205 06/04/11 08:01 AM
Snowtoy Offline
Just a redundancy system, like Toyota does with everything else. Maybe in Japan it is/was common to ignore the first idiot light, so Toyota designers figured they better add another. <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.010s) Memory: 0.6244 MB (Peak: 0.7230 MB) Data Comp: Off Server Time: 2026-11-03 13:38:41 UTC
