suitable engine swaps
#1029299
05/30/11 10:39 AM
I know this is an age-old topic, which gets rekindled every now and then, but here goes...
Has anyone considered an SR20DET conversion or something similar?
Apparently, the SR20's are quite similar (as in displacement being 2.0L, square bore 86mm x 86mm, etc)
I have read that SR20 pistons can be used to make the FE a stroker, but I am curious as to whether or not a full engine swap could be done? Or has anyone attempted something like this before?
1997 Sportage - Extended forks, Dobinsons 2 inch front lift coils, rear Dobinsons TJ lift coils, GME UHF, $8 bullbar (I love eBay!) 2001 HZJ78 Troopcarrier - 2 inch lift, extended shocks, Ex Mine vehicle. Still has yellow reflective stripe! - GONE 2011 Toyota Aurion - For the wife!
Re: suitable engine swaps
[Re: shorty_sporty]
#1029300
06/01/11 08:58 AM
Hardware-wise I think that with an machined adaptor plate for the bellhousing you can fit anything you like ( almost )
The thing is that 10 years now that I have the sporty ONE single report FROM sb that haw actualy done something like that
All yo ucan find is "somebody told me that..." I "have seen a car that..."
Even the actual FE engine there are doubths that actualy fit "as is" ( ofcourse the components and 80% of the design for sure is the same)
So doun the line, is who has the money in the first place, then the time and "courage" to try..
Bellhousing and engine managment are the main problems in short
'96 4d mechanicaly stock so far, rims, spoiler, Cooper AT tyres, Factory LSD, Manual Warn Hubs, handmade exaust, ELECTRIC FAN!!! 3,1'' Lift, PALM GPS http://members.cardomain.com/fokion
[Re: fokion]
#1029301
06/01/11 09:51 AM
Naturally, as with any engine swap from different manufacturers, there would be quite an amount of work to be done.
I purely thought of SR20 as it is a similar size as the Kia engine, but has a plethora of aftermarket spares available.
I am only at the research stage at this point, and I thought I would throw the idea out to some other Kia owners and get some feedback.
I have looked through this forum and see that the FE has quite a few good things going for it. It would be more worthwhile to just modify the existing powerplant. But lack of Mazda piston engine "experts" in Brisbane is quite a hurdle. They all seem to be obsessed with rotaries!
[Re: shorty_sporty]
#1029302
06/02/11 12:57 PM
Hi Shorty Sporty,
There is acompany in Wollongong that is supposd to specialise in the Sporty engine. ADSKIA had his motor rebuilt to be a 2.7 litre torque monster.
Contact ARB in Newcastle and ask to speak to Adam in the workshop. He will be able to point you inthe right direction.
Cheers, Chris
97 Sporty, snorkel, K&N filter,chipped, ext forks, 40mm Dob Springs, KYB struts, 35mm Jeep TJ Springs, RAV 4 OME shocks, Kaiser Locker 5.38 R&P's, 1&3/8 body lift, 245/75 R16 D674's Sports steering wheel, bullbar, extractors & 2 1/4 exhaust engineered.
[Re: 4runnernomore]
#1029303
06/05/11 06:54 AM
Thanks Chris, I will make some enquiries.
If I do end up pursuing the SR20 path, I will do a full write up for everyone.
Cheers, Simon
