95 Montero SR 3.5 V6 coolant leak #1029322 05/31/11 01:00 AM
E
evileric Offline OP
I got a small amount of coolant leaking from the back of the engine every once and a while. Anyone have this problem?
1995 Montero SR factory air locker,33x12.50x15 At's
Re: 95 Montero SR 3.5 V6 coolant leak [Re: evileric] #1029323 05/31/11 01:28 AM
sasnydley Offline
There are several coolant lines that run to the back of the Engine plus- The heater lines. Any of these could be leaking. Plus there is a coolant pipe that runs through the valley of the V-6. It comes off the back of the Water pump. I would check the lines first- They will be hard-But not as hard as the inner coolant pipe.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5874 MB (Peak: 0.6356 MB) Data Comp: Off Server Time: 2026-06-23 03:11:15 UTC
