Engine Oil
#1029449
06/01/11 03:02 AM
My 22re is a little noisy and the o.p. is a little low. I was thinking about going with a thicker oil or maybe a straight weight oil. Any problems with this? Which would be the best to help with my probs?
Thanks to all in advance!!!!!
Big T
Re: Engine Oil
[Re: Brimt]
#1029450
06/01/11 04:01 AM
I find a 15W40 oil works well in my '85/22RE. Have also used a 20W50, but the 15W40 seems to work as well. Plus I use the same stuff in my VW diesel.
My engine is not so much noisy as I find with a thinner oil I find the hot idle oil pressure falls down to the bottom of the factory gauge if I run anything lighter than 40 in it, like a 10W30.
Re: Engine Oil
[Re: 4Crawler]
#1029451
06/01/11 04:04 AM
So the 20w50 wouldnt hurt anything? That seems like it would help boost the o.p. a little and may reduce the chatter i'm hearing. Im also going back to using the toyota brand filters with the anti-drainback valve. Ive used others with anti drainback valves but they dont seem to work as well as the stock toyota ones.
Big T
Re: Engine Oil
[Re: Brimt]
#1029452
06/02/11 12:25 AM
FYI, this is the specs for oil pressure from the FSM. Not a lot of O.P. at idle. ![[Linked Image]](http://pics.montypics.com/oops/2011-06-01/1306970643_fsm_oil_pressure.jpg)
"Serenity through Sobriety"
thicker may or may not be quieter
[Re: Brimt]
#1029453
06/03/11 07:48 AM
'91 22RE; I was using 5w-40...seemed OK. Last summer I tried M1 15W-50: It actually made the valve clacking louder, cold and hot. Went back to 5W-40....quieter now.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6052 MB (Peak: 0.6698 MB) Data Comp: Off Server Time: 2026-06-20 21:42:45 UTCValid HTML 5 and Valid CSS
