Rough Idle #1029462 06/01/11 04:15 AM
Brimt Offline OP
My 22re has started surging while at idle speed. The engine remains at a perfect idle until you press the brake pedal. It only happens when the engine is operating temperature. As soon as you take your foot off the pedal the idling goes back to normal. Does anyone know what this might be?
Thanks guys
Big T
Re: Rough Idle [Re: Brimt] #1029463 06/01/11 05:01 AM
kewlynx Offline
22RE's do not like having low coolant. Make sure that's topped off.
Are you running the AC with this? Turn the AC off and see if you still have the problem. If it goes away, your idle for your AC might be a little low.
**ubi apis- ibi salus**
Re: Rough Idle [Re: kewlynx] #1029464 06/02/11 04:42 AM
Brimt Offline OP
My truck doesnt have AC. I checked the coolant level and its full. Any other ideas? Thought it may be something to do with vacuum issues, but i dont know. Any ideas would be great.
Thanks
Big T
Re: Rough Idle [Re: Brimt] #1029465 06/02/11 09:05 AM
Ralph Offline
How about the brake booster?
Are you using brake fluid?
Ralph
1991 Toyota 4x4 Standard Cab Pickup.
engnbldr cam and head.
Doug Thorley Headers
Home Made Cat Backs
30x9.5x15 BF Goodrich All-Terrain M/T KM2
Re: Rough Idle [Re: Brimt] #1029466 06/02/11 05:37 PM
4Crawler Offline
Thanks guys
Idle speed is likely too high:
- http://www.4crawler.com/4x4/TLCA_TruckTech/TruckTech.04.09.html
Re: Rough Idle [Re: Ralph] #1029467 06/03/11 02:51 AM
Brimt Offline OP
Just checked to see if i was out of fluid, but its full.
Any other ideas?
Thanks for the ideas so far!!
Big T
Re: Rough Idle [Re: Brimt] #1029468 06/03/11 03:31 AM
4Crawler Offline
Any other ideas?
As noted above, idle speed is too high. I can exactly duplicate that issue if I turn my idle speed up to 1000-1100, then hitting the brake causes the loping idle. Turn the idle back down around 800 and all is fine. Also, check the TPS idle setting:
- http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
You can rule out the brake booster by plugging the vacuum line to the booster temporarily and if the problem remains, it is not the booster, but if the problem vanishes, it is likely a vacuum leak in the booster.
Re: Rough Idle [Re: 4Crawler] #1029469 06/03/11 03:50 AM
Brimt Offline OP
I dont have a tachometer. Should i just turn it down a little and see if that helps?
Big T
Re: Rough Idle [Re: Brimt] #1029470 06/03/11 04:21 AM
4Crawler Offline
Easy enough to do. If slower idle fixes the issue, you know the cause.
Re: Rough Idle [Re: 4Crawler] #1029471 06/03/11 04:26 AM
Brimt Offline OP
Well I just dont want to slow my idle too much. Will it hurt my engine if i turn the idle down too low?
Big T
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6435 MB (Peak: 0.7643 MB) Data Comp: Off Server Time: 2026-06-07 06:56:11 UTC
