Can I drive w/out a rear driveshaft?
#1029474
06/01/11 06:38 PM
Is there anyway I can drive (less than 50miles) with out my rear drive shaft in place? Just leave it in 4x4 and run it as FWD? Does the rear drive double as some sore of fluid seal?
1989 Montero 4dr V6 3.0l
Re: Can I drive w/out a rear driveshaft?
[Re: 89montero]
#1029475
06/01/11 07:27 PM
Is there anyway I can drive (less than 50miles) with out my rear drive shaft in place? Just leave it in 4x4 and run it as FWD? Does the rear drive double as some sore of fluid seal? Probably not if you don't seal the xcase after you remove it. It's a slip yoke design and fluid does come out when it's not in place. You can ask some of the regulars who've been on here since the early days how I found this out... (on the Rubicon) <img src="/forums/images/graemlins/shiner.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: 89montero]
#1029476
06/01/11 07:27 PM
The rear driveshaft seals the transfer case. You'd find that out by pulling the rear driveshaft and having the resulting gear lube waterfall.
Don't try driving without it.
[Re: JohnnyBfromPeoria]
#1029477
06/01/11 09:14 PM
I'be done it for a short distance before trying to narrow down a vibration. You can buy a transmission stop off tool. You basically jam this in when you remove tranny's to keep fluid from leaking out. I used mine for about 3 miles or so and it stayed in. If I was going to go longer with it, I would make sure it didn't fall out. Wire, strap sometime so it doesn't pop out. Just like anything, you might break the it or the seal if you jam it in to far or too hard.
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
[Re: heathdogg]
#1029478
06/02/11 01:04 AM
ive moved mine around the yard without a rear driveshaft. but i also dont give a [censored] about mine.
~88 Raider 2.6L 5 speed ~35"x14.5"r15 ~SOA(Spring Over Axle) ~TT(Torsion Twist) ~SBL(Sloped body lift)
[Re: heathdogg]
#1029479
06/02/11 01:04 AM
damn, what was the can size that fit the tcase rear output??
Tomato juice? something...
[Re: fasteddy]
#1029480
06/02/11 01:49 AM
Gatorade Cap over rear output, dont drive far, check it often carry a few spares...Good luck!
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
[Re: justice]
#1029481
06/02/11 01:55 AM
I ran a couple weeks without a rear driveshaft while a new longer one was being made. Put a 2 " rubber plumbing cap, that kinda with a hose clamp on the output housing. It will steer abit funny and eat more gas but you can get by in a pinch,,50 mph is about as fast as I'd go.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
