Engineer Needed (and not the train kind)...
#1029482
06/01/11 09:49 PM
I'm designing a trailer, and need some help understanding the math. If anyone knows how to do beam theory-style math, would you please contact me.
Thanks,
Dave
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5 1992 Chrysler LeBaron Convertible: 3.0/A 1994 GMC Safari: 4.3/A
Re: Engineer Needed (and not the train kind)...
[Re: WagonMaster]
#1029483
06/01/11 10:47 PM
Oscar
[Re: WagonMaster]
#1029484
06/01/11 11:11 PM
I can't answer those questions but perhaps this can help?
[Re: off-roader]
#1029485
06/01/11 11:55 PM
The bending moment and shear forces vary along the beam length and are often represented diagramatically.
These internal forces may vary along the length of the beam and are usually represented as separate bending moment and shear force diagrams.
The calculation of bending moments and shear forces is traditionally part of structural analysis and is beyond the scope of this unit.
Don't know how mathy you are, but this can get real hairy. There should already be some free trailer plans out there with all the engineering already done. I seen to remember something called finite element analysis that used a Kray or something to do the number crunching, but that was a while ago. Probably do it on your phone now...
[Re: fasteddy]
#1029486
06/02/11 02:07 AM
Alas, not mathy at all.
The big question right now is that a trailer parts supplier tells me that a drop axle significantly increases the effective axle overhang past the spring perch. Unfortunately, he doesn't know enough to be able to explain it. As I plan to use a drop, I figure that the actual math would be a good thing to know.
[Re: perucho]
#1029487
06/02/11 02:09 AM
5,000# (max) drop axle trailer.
[Re: WagonMaster]
#1029488
06/02/11 05:11 AM
No math required, just common sense.
If you have a straight axle, you can put the spring perches anywhere up to the back of the hub, so you can minimize the amount of axle between the wheel and the perch.
If you have a drop axle, you can't put the perches in the bend area of the "drop" of the axle, you have to go inboard to the flat section of the axle to place the perch. Since most of the drop profile's I've seen are a ess-ish shape (two 45ish degree bends), instead of a right angle and a right angle, the distance becomes significant,
[Re: fasteddy]
#1029489
06/02/11 06:07 AM
If you have a drop axle, you can't put the perches in the bend area of the "drop" of the axle, you have to go inboard to the flat section of the axle to place the perch. Since most of the drop profile's I've seen are a ess-ish shape (two 45ish degree bends), instead of a right angle and a right angle, the distance becomes significant, This axle... http://www.northerntool.com/shop/tools/product_200330525_200330525...for example, appears to have about a 2" "S" as the drop. On a 72" axle (arbitrarily), would the 2" on a side really make that much difference? This is why I need the math... <img src="/forums/images/graemlins/confused.gif" alt="" />
[Re: WagonMaster]
#1029490
06/02/11 04:57 PM
OK, found the answer I needed.
WOW!
What a difference a few inches makes... <img src="/forums/images/graemlins/scared.gif" alt="" />
[Re: WagonMaster]
#1029491
06/02/11 06:19 PM
X2!
1999 Mitsu Montero - Crappy Weather 1992 Isuzu Pickup - Zombie Apocalypse 2008 Saturn Sky Redline - Nice Weather
