Weak spark on one cylinder #1029510 06/02/11 05:02 AM
89montero Offline OP
Been trying to sort out all the various issues these last few days. y engine runs pretty rough so with the engine running I removed each wire one by one, all cylinders had the same effect except for #1(passenger closest to grill) which made no difference at all in engine RPM. I have replaced the fuel injector with a know good one and no difference. When I pulled the wire and hold it close to a ground it is SIGNIFICANTLY weaker than the other cylinders. All the other wires you close hold fairly close to a ground and it rapidly arcs however the #1 cylinder wire must be almost touching the ground and even then it has a weak arc.
The cap and rotor aren't brand new but are in good shape. I will try a new wire and new plug but does anyone have any other ideas?
1989 Montero 4dr V6 3.0l
Re: Weak spark on one cylinder [Re: 89montero] #1029511 06/02/11 05:14 AM
New wire, cap, rotor. Plug didn't get tested, so why change it?
If that doesn't do it, look for a dirty slot wheel in the crank position sensor in the dizzy...
Re: Weak spark on one cylinder [Re: fasteddy] #1029512 06/02/11 06:34 AM
P
perucho Offline
New wire, cap, rotor. Plug didn't get tested, so why change it?...
What he said. You can also use that wire for a different plug and see if the spark intensity changes. If it's still weak, then it's most likely just the wire. Pull the plug and clean it/ gap it. If the spark was weak it may be somewhat fouled.
Oscar
Re: Weak spark on one cylinder [Re: perucho] #1029513 06/02/11 08:16 AM
Did that test and the wire/plug seems fine, looks like it's the #1 outlet on the cap that's not giving a strong spark. I will get a new cap and rotor tomorrow and hopefully that fixes it otherwise, as said above, must be the sensor inside the contributor.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6037 MB (Peak: 0.6599 MB) Data Comp: Off Server Time: 2026-05-26 04:55:45 UTC
