Key for 85 Toyota 4runner #1029546 06/03/11 09:57 PM
W
WolvesCross Offline OP
I gave my 4Runner to my niece, who just loves her 4runner, but she is having problems with the key to start and unlock the 4runner. It is worn down, I call my local dealership's part man he couldn't find his way out of a box. Does any body know how I can maybe get another key from Toyota if its possible.
85 Toyota 4Runner SR5 4X4 4cyl. EFI(Procomp 4" lift)
Re: Key for 85 Toyota 4runner [Re: WolvesCross] #1029547 06/03/11 10:41 PM
toyrunner Offline
Pull the cylinder from the ignition switch. Take it to a locksmith. Have him make a key for it. Done...
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: Key for 85 Toyota 4runner [Re: toyrunner] #1029548 06/04/11 12:16 AM
W
Didn't think about that, thanks I'll do that.
Re: Key for 85 Toyota 4runner [Re: WolvesCross] #1029549 06/04/11 02:23 AM
CJM Offline
actually .. I believe the passenger lock assy has the key code on it .. might be easier ?
83 Trekker SR5
NEW Trekker forum
Re: Key for 85 Toyota 4runner [Re: WolvesCross] #1029550 06/06/11 01:45 AM
kewlynx Offline
If the key doesn't have a chip on it, just take it to a hardware store that makes keys and get a new one cut.
**ubi apis- ibi salus**
Re: Key for 85 Toyota 4runner [Re: WolvesCross] #1029551 06/07/11 02:57 PM
G
Greg_Canada Offline
His problem is the original key cannot be copied.
As corey said, the passenger side lock cylinder has the key code on it. take it and bring it to a locksmith to cut you a key. get a new key blank from toyota if you want the best quality...
89 4Runner
Re: Key for 85 Toyota 4runner [Re: Greg_Canada] #1029552 06/08/11 02:19 AM
toyrunner Offline
Still easier to pull the ignition cylinder and have a real locksmith make a key. They can do that.
Door panels take more time to pull than the ignition cylinder.
I like the quick and easy approach...v <img src="/forums/images/graemlins/baby.gif" alt="" />
1985 SR5 4Runner
4.7:1 single case
Re: Key for 85 Toyota 4runner [Re: WolvesCross] #1029553 06/08/11 02:23 AM
toyrunner Offline
Run some graphite in the locks to help free them up. I blast carb cleaner in them first, then blow dry with compressed air. This gets all the dirt out. Then lube with graphite powder. Works like a charm.
1985 SR5 4Runner
4.7:1 single case
Re: Key for 85 Toyota 4runner [Re: toyrunner] #1029554 06/08/11 02:14 PM
G
Greg_Canada Offline
How do you take out the ignition cylinder? I can get the door panels off in minutes....
89 4Runner
Re: Key for 85 Toyota 4runner [Re: Greg_Canada] #1029555 06/08/11 09:13 PM
toyrunner Offline
You pull the top and bottom cover off the steering column. Then insert the key and put a paperclip in the release hole that is in the switch housing. Then turn the key to accessory position and pull the cylinder out. Simple and you don't have to fight with the door panel and the little plastic clips that like to break, or the clip that retains the lock in the door.
If you have experience with doing this sort of repair, maybe it is easier to go this way. I would still pull the ig. cyl. Much faster with less chance of breaking any little pla$tic clip$ that are co$tly from Toyota.
ymmv <img src="/forums/images/graemlins/cheers.gif" alt="" />
1985 SR5 4Runner
4.7:1 single case
PHP: 7.4.33 Page Time: 0.018s Queries: 16 (0.013s) Memory: 0.6422 MB (Peak: 0.7624 MB) Data Comp: Off Server Time: 2026-11-04 19:59:07 UTC
