Which transfer case will work?
#1029854
06/09/11 08:54 PM
I have a 1995 Montero SR, im wanting to do a SAS on it with D60 front and 14 bolt rear. Which transfer case bolts up to my transmission? I think it might be a NP231? Any and all help would be appreciated!
1995 Montero SR factory air locker,33x12.50x15 At's
Re: Which transfer case will work?
[Re: evileric]
#1029855
06/09/11 09:26 PM
driverside or passengerside drop d60?
[Re: RECON45]
#1029856
06/09/11 09:37 PM
the D60 im lookin at is a DSD because of the stock layout tcase.
[Re: evileric]
#1029857
06/09/11 09:56 PM
I don't think a corp 14 bolt is any stronger than the stock 9.5" axle. Be curious to see the "specs" on them. Have to fiddle with the coils and arms or go to leafs to get the travel I bet you are looking for.
[Re: fasteddy]
#1029858
06/09/11 10:13 PM
that may be, but i dont want a fullsize front axle and stock width rear axle. and also ring/pinion and locker aftermarket support. If im swapping axles and sas it, the rear coil setup's not a big task.
So back to that Transfer case! It looks like it is the NP231, but which one? Thanks for the help guys.
[Re: evileric]
#1029859
06/10/11 04:42 AM
23 Spline short input shaft.
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
[Re: justice]
#1029860
06/10/11 04:49 AM
thanks man. I appreciate it.
[Re: evileric]
#1029861
06/10/11 06:18 AM
The NP241 will work as well which is a big upgrade over the NP231.
Spence 1985 Mitsubishi PU 2.3 Turbo Diesel, 13" lift, Watercooled turbo, 4D56 Head, Atlas II,Fox Coilovers, Elockers,
1983 Mitsubishi PU 2.5 Turbo Diesel 4x4, fully restored
2003 G500, sliders, beadlocks, roofrack, ladder etc.
[Re: spencevans]
#1029862
06/10/11 04:30 PM
is it a direst bolt in? any needed specifics on the np241?
[Re: evileric]
#1029863
06/10/11 05:34 PM
You can get the slip yoke kit for the 231 or the 241. They are both 2.72:1 low range unless you can find a 241 from a wrangler rubicon. That one has 4:1 low range but you can get the low range kit for a 231 to make it 4:1. I don't remeber but I thought I read the 241 had a beefier chain and plantery's. You can upgrade the 231 with beefier chain and plantery's from a dodge 231dhd. http://www.4x4wire.com/jeep/tech/xfer/np231hd03/Here's that article. I'm sure I screwed up somewhere. Some one will correct me if I'm wrong.
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
