Which transfer case will work? #1029854 06/09/11 08:54 PM
E
evileric Offline OP
I have a 1995 Montero SR, im wanting to do a SAS on it with D60 front and 14 bolt rear. Which transfer case bolts up to my transmission? I think it might be a NP231? Any and all help would be appreciated!
1995 Montero SR factory air locker,33x12.50x15 At's
Re: Which transfer case will work? [Re: evileric] #1029855 06/09/11 09:26 PM
RECON45 Offline
driverside or passengerside drop d60?
Re: Which transfer case will work? [Re: RECON45] #1029856 06/09/11 09:37 PM
E
evileric Offline OP
the D60 im lookin at is a DSD because of the stock layout tcase.
Re: Which transfer case will work? [Re: evileric] #1029857 06/09/11 09:56 PM
I don't think a corp 14 bolt is any stronger than the stock 9.5" axle. Be curious to see the "specs" on them. Have to fiddle with the coils and arms or go to leafs to get the travel I bet you are looking for.
Re: Which transfer case will work? [Re: fasteddy] #1029858 06/09/11 10:13 PM
E
evileric Offline OP
that may be, but i dont want a fullsize front axle and stock width rear axle. and also ring/pinion and locker aftermarket support. If im swapping axles and sas it, the rear coil setup's not a big task.
So back to that Transfer case! It looks like it is the NP231, but which one? Thanks for the help guys.
Re: Which transfer case will work? [Re: evileric] #1029859 06/10/11 04:42 AM
justice Offline
23 Spline short input shaft.
Re: Which transfer case will work? [Re: justice] #1029860 06/10/11 04:49 AM
E
evileric Offline OP
thanks man. I appreciate it.
Re: Which transfer case will work? [Re: evileric] #1029861 06/10/11 06:18 AM
spencevans Offline
The NP241 will work as well which is a big upgrade over the NP231.
Spence
1985 Mitsubishi PU 2.3 Turbo Diesel, 13" lift, Watercooled turbo, 4D56 Head, Atlas II,Fox Coilovers, Elockers,
1983 Mitsubishi PU 2.5 Turbo Diesel 4x4, fully restored
2003 G500, sliders, beadlocks, roofrack, ladder etc.
Re: Which transfer case will work? [Re: spencevans] #1029862 06/10/11 04:30 PM
E
evileric Offline OP
is it a direst bolt in? any needed specifics on the np241?
Re: Which transfer case will work? [Re: evileric] #1029863 06/10/11 05:34 PM
heathdogg Offline
You can get the slip yoke kit for the 231 or the 241. They are both 2.72:1 low range unless you can find a 241 from a wrangler rubicon. That one has 4:1 low range but you can get the low range kit for a 231 to make it 4:1. I don't remeber but I thought I read the 241 had a beefier chain and plantery's. You can upgrade the 231 with beefier chain and plantery's from a dodge 231dhd.
http://www.4x4wire.com/jeep/tech/xfer/np231hd03/
Here's that article. I'm sure I screwed up somewhere. Some one will correct me if I'm wrong.
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6353 MB (Peak: 0.7423 MB) Data Comp: Off Server Time: 2026-06-22 14:17:20 UTC
