Re: Which transfer case will work? [Re: evileric] #1029864 06/10/11 06:05 PM
LandRaider Offline
is it a direst bolt in? any needed specifics on the np241?
This one is untested as far as I know. At a BARE minimum, you will need to install a super short SYE kit for an output shaft.
a 231CHD will also provide doner parts to beef a 231j
Re: Which transfer case will work? [Re: LandRaider] #1029865 06/11/11 08:35 PM
E
evileric Offline OP
ok, coming from jeep tech guys i ride with, im going with a NP231. they said the 231 is better than the 241, so thats what im going with.
whats a 231 CHD? is that a direct bolt in? I see you're using it, but you're not running Mitsu engine/trans.
1995 Montero SR factory air locker,33x12.50x15 At's
Re: Which transfer case will work? [Re: evileric] #1029866 06/11/11 10:40 PM
justice Offline
Its a heavy duty version of the 231 (thats what the "HD" stands for). The input is not compatible with the mits, but I heard that you can swap the input from a regular 231 into it to make it fit. I had one in my garage for a minute, it looked like case was the right size, but input splines did not match the extra trans I have in the garage.
Re: Which transfer case will work? [Re: evileric] #1029867 06/12/11 02:49 AM
LandRaider Offline
CHD is a Chevrolet heavy duty NP231. Comes in S10 blazers with 4.3 motors. It will not bolt to a mitsu trans. I run all chevy drivetrain, so that's how I got mine.
6 pinion planetary, and 2 inch wide chain. Ultimate Beef NP231.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.006s) Memory: 0.6089 MB (Peak: 0.6817 MB) Data Comp: Off Server Time: 2026-06-22 14:17:18 UTC
