Universal joint #1029886 06/10/11 12:14 AM
SledgeHammer Offline OP
Is this an easy repair or it is like the trooper I owned and they have to be pressed on?
Hearing clunk when i back up and stop and feeling slight vibration.
1991 Montero RS
Re: Universal joint [Re: SledgeHammer] #1029887 06/10/11 12:54 AM
RECON45 Offline
i replaced mine by using a socket and drive them out and drive the new ones back in.
Re: Universal joint [Re: RECON45] #1029888 06/10/11 01:52 AM
I hope it's that easy cause the trooper ws expensive as hell to replace.
1991 Montero RS
Re: Universal joint [Re: SledgeHammer] #1029889 06/10/11 06:22 PM
heathdogg Offline
I do mine with a vise and sockets. My aim ain't so great with a hammer. I use the vise at work. In and out without bruised fingers/hand.
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
Re: Universal joint [Re: heathdogg] #1029890 06/10/11 07:30 PM
RECON45 Offline
That was the method I was going to do, but the vise was about 3/4" short to fit the 2 sockets and ujoint
Re: Universal joint [Re: RECON45] #1029891 06/11/11 12:39 AM
F
From_jeep_to_raider Offline
You dont need a socket on both sides. Just get the joint in the vise and bang on the top most one with a socket and hammer. Then turn and repeat. Thats how I do it anyway.
Re: Universal joint [Re: SledgeHammer] #1029892 06/11/11 01:27 AM
Va_Stumpy Offline
1 socket & a vise will do..Once they are flush , use washers, or some thin spacer on opposite sides. Viola!..... you are done! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: Universal joint [Re: Va_Stumpy] #1029893 06/11/11 02:40 AM
so,these aren't ike the isuzu troopers where u have to have them pressed on?
1991 Montero RS
Re: Universal joint [Re: SledgeHammer] #1029894 06/11/11 01:39 PM
JAVYPRO Offline
Nope, and if the C clip doesn't fit, sometimes they are a little too thick, go to Home Depot and there you will find a thinner one for less than $1.50.
Replacing the joints is a breeze.
Good luck, keep us posted on your progress.
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6256 MB (Peak: 0.7122 MB) Data Comp: Off Server Time: 2026-06-20 21:41:59 UTC
