Stiff clutch pedal if sitting at idle for a while #1030340 06/18/11 04:54 AM
promodmerc Offline OP
Tonight I was sitting in a drive through for 5+ minutes and the clutch pedal got pretty stiff. It felt like a 60's muscle car with a race clutch <img src="/forums/images/graemlins/lol.gif" alt="" /> It was also hard to get into gear. It didn't grind the gears but it took a little bit of force to get in gear and also when up shifting.
Now after driving for a mile or so it was back to normal. This is not the first time it has happened. I never have a problem if it sits over night so it has to be something going on while it is running. I also don't have a problem in rush hour stop & go traffic.
Re: Stiff clutch pedal if sitting at idle for a while [Re: promodmerc] #1030341 06/19/11 10:57 AM
Axe Man Offline
Kia Moderator Emeritus
Check the clutch slave cylinder on the passenger side of the bellhousing. If there's any dampness or indication of brake fluid leak you've found the problem.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5863 MB (Peak: 0.6346 MB) Data Comp: Off Server Time: 2026-10-21 20:43:56 UTC
