Engine Rebuild or Swap #1030444 06/19/11 10:52 PM
fatrat Offline OP
My 1st gen 3.0 Montero LWB is now blowing white smoke like crazy so I am either going to rebuild or swap to a different motor. I would love to go diesel but after much research think it's going to be a major PITA & a lot of $$$. My other choice is a 4.3 (tons of cheap Blazers on CL). I have done a lot of searching & can't find much info on doing the 4.3 swap. Is it worth it or should I just rebuild the 3.0? This vehicle will be used for my family expo vehicle & DD. Any advice will be much appreciated.
89 LWB V6 auto - LSD - OME coils, torsions, & nitrochargers - Rugged Ridge hubs -
Re: Engine Rebuild or Swap [Re: fatrat] #1030445 06/19/11 11:56 PM
0778drz110 Offline
You need to think about these things if your doing a swap:
Welder/ metal for mounts
Driveshafts
Speedometer
Shifter
Alternator
A/C
Power steering
Vacuum lines
Engine wiring
Throttle cable
Body lift or floor cutting
Tachometer
Air intake tubes and filter
Exhaust and o2 sensors
Radiator
Fans
How you plan to lift the engines in and out
4x4 shifter
Etc.
Good luck! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Engine Rebuild or Swap [Re: fatrat] #1030446 06/20/11 05:55 AM
hazy_daze Offline
I rebuilt mine and I've been very pleased with it. Search my username and "To rebuild or not to rebuild" and you'll see a bunch of pictures documenting my overhaul. You can also search username FrankR and "Bob's engine build" and it'll give you plenty of info. Where are you in GA?
Re: Engine Rebuild or Swap [Re: 0778drz110] #1030447 06/20/11 07:11 AM
[quote]You need to think about these things if your doing a swap:
Driveshafts
Speedometer
Shifter
Alternator
A/C
Power steering
Vacuum lines
Engine wiring
Throttle cable
Tachometer
Radiator
Fans
4x4 shifter
Etc.
Dillon, great checklist for anyone contemplating a swap. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Engine Rebuild or Swap [Re: Mudraider] #1030448 06/20/11 09:20 PM
fatrat Offline OP
Great info!
I guess I'll rebuild since I want to get it back on the road quick as possible. Does anybody know any good shops to work on the Montero in the Atlanta area? I've used OPM in Cumming for a couple rebids but they don't want to handle the Mitsubishi. I would do it but don't have time theses days due to work.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6089 MB (Peak: 0.6747 MB) Data Comp: Off Server Time: 2026-05-29 15:38:43 UTC
