Weber carb install #1030592 06/22/11 03:59 PM
P
PhantomSky2 Offline OP
More questions from meee.
Anyways, just wondering about the electric choke on the weber carb...where exactly do you hook it up?
Re: Weber carb install [Re: PhantomSky2] #1030593 06/22/11 08:01 PM
cdl1701 Offline
I hooked mine into the the plug where the original carb plugged in. I just found the hot wire and used that. Actually I cut the plug off of the old carb and attached it to the choke wire so that it would make a cleaner look.
88 Montero, 2.6 Black
Re: Weber carb install [Re: cdl1701] #1030594 06/22/11 08:17 PM
socal1200r Offline
What he said...but be sure to use a test meter to connect the wires to the right female ends in the stock plug. From what I remember, all you need is one that's hot when you turn the key...
1989 Monty SWB, 2.6L w/MT, 15" alloys, 265/75 Dunlop Radial rovers, rear air shocks, Weber 32/36, SQ oil cooler, (SOLD Oct 2012)
Southeast VA, USA
Re: Weber carb install [Re: cdl1701] #1030595 06/23/11 02:28 AM
plh Offline
Same here...
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Weber carb install [Re: plh] #1030596 06/23/11 02:35 AM
The SWB I just got has a manual choke cable on it! <img src="/forums/images/graemlins/barf.gif" alt="" /> What is the difference, like $20 between a manual and the electric choke? Why would anyone even bother? <img src="/forums/images/graemlins/confused.gif" alt="" /> Worst part was before I bought it I threw away a couple of locked up progressives that I could of grabbed up the electric chokes from. <img src="/forums/images/graemlins/angry.gif" alt="" /> Oh well.
Re: Weber carb install [Re: Mudraider] #1030597 06/23/11 07:55 PM
P
Well, we got it all installed and adjusted the idle but cant seems to be always running rich no matter how much we adjust the mixture and timing...
Re: Weber carb install [Re: PhantomSky2] #1030598 06/24/11 03:15 AM
Skibane Offline
Did you adjust the choke?
The Redneck Special: 88 Ram 50 2WD XCab with 167K on the original 2.6L, 5-Sp, Weber 38DGS, Crane HI-6 with timing adjust, 4-for-$100 tires, Generac 4000EXL 4KW AC generator, Hampton Bay 12KBTU window air conditioner sticking through a hole hacked in the back of the cab...All it needs now is a gun rack...
Re: Weber carb install [Re: Skibane] #1030599 06/24/11 05:06 AM
zarktheshark Offline
you shouldn't be tuning the carb when it's cold, so the choke shouldn't be the issue. I just rebuilt my carter and it made a big difference with the idle. It was complete crap before. Is your carb used? If so, spend the $20 on the gasket kit and replace them and the O rings. then, while everything is out, I ran a fair amount of carb cleaner through all the passages. put it all back together (twice because i put the floats on upside down) <img src="/forums/images/graemlins/scared.gif" alt="" /> Then adjust the throttle positioning screw until the screw touches, then turn in 1 1\2 times, no more. Adjust the idle mixture screw so it barely bottoms out, then back it off 1 full turn. adjust in 1\4 turn incriments until you get it where you want. I'm running around 600rpm in gear and 850ish in N. For the electric choke, you have to preload the spring by turning the choke one way or the other, then lock it down with the hold down ring. There is a fast idle screw that just holds the throttle position a little higher than the regular screw, that one i tuned it until it was around 1500rpm(i think). hope this helps.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: Weber carb install [Re: zarktheshark] #1030600 06/24/11 06:04 AM
Skibane Offline
It will be an issue if it's set too rich to shut off completely after the engine warms up.
Re: Weber carb install [Re: Skibane] #1030601 06/25/11 08:59 AM
P
meh, figured out the piston rings are fried so....rebuild for me.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6291 MB (Peak: 0.7379 MB) Data Comp: Off Server Time: 2026-11-03 20:12:58 UTC
