Timing belt broke on co-workers 95 Trooper #1030887 06/28/11 06:56 PM
LRJ4x4 Offline OP
I told her I would ask the Trooper guys if it's a Interference engine. Google is full of conflicting information.
Thanks
Re: Timing belt broke on co-workers 95 Trooper [Re: LRJ4x4] #1030888 06/30/11 09:17 PM
BigSwede Offline
AFAIK, no. But I've never tested it...
Serenity now!
Re: Timing belt broke on co-workers 95 Trooper [Re: LRJ4x4] #1030889 07/01/11 03:34 AM
Ed Mc Offline
The Isuzu-built 3.2 is a non-interference motor. No valves should be crunched. The biggest penalty for letting the belt replacement go on these is the potential for breakage somewhere down the road, with resultant non-running engine.
Take 'er down and install a new belt & water pump (the pump replacement being that compared to the cost of tearing it down again for a pump replacement, the pump price is relatively small).
Also recommend renewing hydraulic belt tensioner(s), as they are known to be problematic as well. When a belt tensioner goes bad it'll cause a noise that sounds exactly like a bad rod bearing.
HTH..........ed
'90 Troop 3.4 LS
'89 Troop RS (Has Valve Issues, needs Counseling)
HI, I'm Ed and I'm a Trooper-holic!
Keep On Troopin'......
Re: Timing belt broke on co-workers 95 Trooper [Re: Ed Mc] #1030890 07/01/11 03:12 PM
Jim_Paget Offline
And Big Swede (Steve)does know about changing the tensioner in a campground. Not the way to spend a day in Moab.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Timing belt broke on co-workers 95 Trooper [Re: Jim_Paget] #1030891 07/02/11 09:33 PM
BigSwede Offline
At least we had a shade tree to work under...
Serenity now!
Re: Timing belt broke on co-workers 95 Trooper [Re: LRJ4x4] #1030892 12/03/11 04:46 PM
Chad Hunter Offline
I have had the occasion to loose a timing belt on my '96 trooper. On the freeway north of Las Vegas at speed. Motor suffered no ill effects. I don't recomend replacing the belt in a supermarket parking lot, however.
1987 trooper LS.'94 3.2, SAS,35's , lots of dents and rust. Now, improved, with more dents.
1995 trooper LS. Wife won't let me improve this one.
1996 trooper. I'll need something to modify when the '87 finally rusts away.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6103 MB (Peak: 0.6796 MB) Data Comp: Off Server Time: 2026-10-22 07:38:19 UTC
