Front sealed bearing? #1031225 07/04/11 09:16 PM
MADDOG Offline OP
Howdy, all.
I'm rebuilding a 5-speed from my 88 Monty, but I can't seem to find a source for the front sealed bearing. I've seen bearing kits, but they are sans the front bearing. It's 80mm OD x 35mm ID. It's an NTN, but I can't even seem to locate it on the NTN site. The other bearings seem okay, so I don't think I want a whole kit.
Thanks for any help.
Re: Front sealed bearing? [Re: MADDOG] #1031226 07/04/11 09:24 PM
Howdy, all.
Did you try looking it up on the Mitsu ASA program?
Re: Front sealed bearing? [Re: off-roader] #1031227 07/04/11 09:26 PM
MADDOG Offline OP
No - I don't know what that is..
Re: Front sealed bearing? [Re: MADDOG] #1031228 07/04/11 09:52 PM
haztoys Offline
Rockauto has it listed for $30...
Re: Front sealed bearing? [Re: MADDOG] #1031229 07/04/11 11:16 PM
Check the FAQ's for it. Mitsu ASA is the program dealers use to look up parts/part numbers. Runs on Windows. Downloadable online. Again check the FAQ for links. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Front sealed bearing? [Re: off-roader] #1031230 07/05/11 04:03 PM
MADDOG Offline OP
Thanks, guys. I'll get one from Rockauto. Does anyone know of any quality differences between Timken and National bearings? The National costs more, but I can't believe Timken would be inferior...
Re: Front sealed bearing? [Re: MADDOG] #1031231 07/05/11 08:19 PM
hazy_daze Offline
I'd go with Timken.
Re: Front sealed bearing? [Re: hazy_daze] #1031232 07/06/11 10:33 AM
A
airbats801 Offline
check and see where both are made. I;'ve seen timken selling seals made overseas. I'm not sure about their bearings.l I figure anything from japan or the states should be solid.
8 Starion SHP, 87 mitsubishi van, , 81 galant g54bt, 78 lancer g54bt, 1965 Mitsubishi Debonair Deluxe
87 swb montero offroad pkg goin g54bt with sr locker 33x12.5 dual bouncy.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6222 MB (Peak: 0.7041 MB) Data Comp: Off Server Time: 2026-06-09 23:21:51 UTC
