2002 front rotors #1031724 07/14/11 02:44 PM
jolly4x4 Offline OP
I upgraded to Powerslot front rotors about 70k ago and they had a vibration since day 1. Its grown worse and couldn't stand it any more. I replaced them myself last weekend (with another set of powerslots - from Tire Rack). Used another set of the factory pads - love them as they are dust-free. The job went fine except after putting the caliper on and spinning the rotor (no pads) I could see that it had a serious wobble in it. I took a sledge and a block of wood and "applied vigorous pressure" around the hub and that made a big difference. Bled the system (replaced all fluid) and initial results are good.
Wondering if the guys who did the job last time simply didn't have the rotor on all the way - aaargh!
Jack Jolly
2002 4Runner Sport Edition
Gangsta Black
Re: 2002 front rotors [Re: jolly4x4] #1031725 07/14/11 08:13 PM
G
Greg_Canada Offline
They probably left some crap in there...
always make sure to clean off the mating surface really well...
i hate lazy mechanics...
89 4Runner
Re: 2002 front rotors [Re: jolly4x4] #1031726 07/18/11 05:09 AM
Jeff the marmot Offline
Yeah, that sounds like more than just normal warping of the rotor.
When you get sick of warped rotors and want to really resolve the problem, you should swap to the thicker Tundra rotors and calipers. I've had no warping at all with my Tundra brakes, despite a period of time where I basically only had front brakes due to leaky rear axle seals that soaked my rear brake drums with gear lube. My previous post about the Tundra brakes is at:
http://www.4x4wire.com/forums/showf...1162935&Main=1162763#Post1162935
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.5966 MB (Peak: 0.6506 MB) Data Comp: Off Server Time: 2026-10-22 04:05:52 UTC
