ENGINE / TRANS SWAP 91 MONTERO #1031914 07/17/11 07:21 PM
hampster Offline OP
WILL ENG/TRANS FROM A 96/97 SWAP INTO MY 91 3.0 AUTOMATIC TRUCK ?
Re: ENGINE / TRANS SWAP 91 MONTERO [Re: hampster] #1031915 07/18/11 01:06 AM
mxmikie Offline
can it be any engine and trans ????? or do you have something in mind ??????
Re: ENGINE / TRANS SWAP 91 MONTERO [Re: mxmikie] #1031916 07/18/11 01:26 AM
search srtnate for his 3.5 swap into an 89. There are solvable problems with fit.
Re: ENGINE / TRANS SWAP 91 MONTERO [Re: hampster] #1031917 07/18/11 05:30 AM
The simple answer is YES.Search can be your friend here.
Re: ENGINE / TRANS SWAP 91 MONTERO [Re: Mudraider] #1031918 07/18/11 05:59 AM
mxmikie Offline
go with the LT-1 and L480E or the northstar and the L460E
Re: ENGINE / TRANS SWAP 91 MONTERO [Re: mxmikie] #1031919 07/18/11 04:19 PM
It would be a lot easier swapping in a later 3.0 or 3.5. Mounting it up and all the accessories should fit a lot easier to make it work.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6076 MB (Peak: 0.6769 MB) Data Comp: Off Server Time: 2026-06-24 07:28:52 UTC
