tools advice and parts for a timing belt change
#1031976
07/19/11 04:34 AM
Ok been looking with the search function to try to see if i can find a write up on a timing belt change on a 3.5 if there is one i missed it.. So i guess first off if there is one and if anyone knows of it can you put me in the right direction please... And i was also wondering what parts and tools to do a good job .. And while i got it torn a part anything else i should look at or do ? The old lady does have 196 thousand miles on her. thank you everyone... <img src="/forums/images/graemlins/kewl.gif" alt="" />
95 SR stock but i hope not for long....
Re: tools advice and parts for a timing belt change
[Re: leftnutt35]
#1031977
07/19/11 05:01 AM
change the water pump cam and crank seals and timing belt T-Belt Tension Adjuster and both pulleys timing belt kit
[Re: mxmikie]
#1031978
07/19/11 05:19 PM
change the water pump cam and crank seals and timing belt T-Belt Tension Adjuster and both pulleys timing belt kit Wrong kit, that one is for a SOHC.
Michael j
TreadLightly! Trainer
[Re: Grasscat]
#1031979
07/19/11 06:49 PM
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6037 MB (Peak: 0.6599 MB) Data Comp: Off Server Time: 2026-06-07 04:37:46 UTCValid HTML 5 and Valid CSS
