Rebuild an alternator #1031989 07/20/11 05:30 PM
Y
yotadiehard Offline OP
Could some one tell me how and what I need to rebuild my alternator for a 88' 4wd pickup with a 22re motor? Hoping it is cheaper than buying a new one.
Re: Rebuild an alternator [Re: yotadiehard] #1031990 07/20/11 05:45 PM
4Crawler Offline
Re: Rebuild an alternator [Re: 4Crawler] #1031991 07/21/11 02:56 PM
DRX350 Offline
^^^ Very likely that it is the brushes, but by the time you find them, install them, and all, it may be worth just buying the $50-60 cheapo alt...
"Does this part need to be in there?"
1996 Dodge 1500 single cab / short bed, 5.9 4x4; 2" lift (springs not blocks), C.A.I and more mods to come.
Re: Rebuild an alternator [Re: DRX350] #1031992 07/21/11 03:03 PM
Staceman Offline
If it is the original stock TOYOTA alt, do the brushes. Probably good for at least another 10 years, 100K miles. Get a cheapo swap out, you may by swapping annually. My 1985 has the original alternator. I did the brushes at 145,000 miles. I now have 270,000 miles. I may need brushes soon. I have not had issues since I did them in the spring of 2003.
Re: Rebuild an alternator [Re: yotadiehard] #1031993 07/28/11 10:01 AM
Snowtoy Offline
Check around your community and see if there is a small electric motor repair shop. I just had the alt from my '90 3.0 cleaned/full rebuild this spring for $85.
Re: Rebuild an alternator [Re: DRX350] #1031994 07/31/11 04:47 PM
matts Offline
I put new brushes in the alternator on my '84 twice. at 240k miles it was still running strong. I never had any trouble finding brushes at NAPA. They cost around $5.00 last time I bought them. You will need a soldering iron both to remove the old brushes and to install the new ones. Sometimes "parts store" replacement alternators are not even OEM based, but are actually Chinese knock-offs. I prefer to rebuild an original piece.
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: Rebuild an alternator [Re: Snowtoy] #1031995 08/01/11 01:14 AM
kewlynx Offline
I also use our local automotive electric rebuilders, as the dealers do.
If you don't have a soldering iron for redoing just the brushes, you should be able to order the brushholder assy w/the brushes from the Toyota dealer.
If the armature is fine (alt OR starter), keep your OEM parts. 'Cheapo' alternators are sometimes exactly that; caveat emptor.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6223 MB (Peak: 0.6970 MB) Data Comp: Off Server Time: 2026-05-29 22:27:09 UTC
