Ac refill #1032002 07/20/11 09:38 PM
fire4effect Offline OP
My ac was converted to 134a a few months ago. I found and fixed the leak, now I have to refill it. The instructions say to look for 'low side' port btwn evap n comprsr. Does anyone know where that is? I can see 2 valves near the firewall/charcoal canister, but they seem too far
Semper Fi,
Alfred
'91 4Runner V6 4WD 400+K
'10 Scion Xb
Re: Ac refill [Re: fire4effect] #1032003 07/21/11 02:56 PM
Staceman Offline
Not sure exactly where on the V6, just follow the A/C line between the firewall and the compressor. That is low side and the port should be along there somewhere. The line from the compressor to the condensor in front of the radiator is the HIGH side. Stay away from that one.
Re: Ac refill [Re: Staceman] #1032004 07/22/11 11:18 PM
Staceman Offline
Best pic I could find in your FSM
Re: Ac refill [Re: Staceman] #1032005 07/27/11 08:21 PM
Thx that helped a lot!
Semper Fi,
Alfred
'10 Scion Xb
Re: Ac refill [Re: fire4effect] #1032006 07/27/11 09:24 PM
Staceman Offline
Stay Cool!
.......Literally.....
Re: Ac refill [Re: fire4effect] #1032007 07/31/11 09:16 PM
matts Offline
Before refilling it probably needs to be placed under a high vacuum to remove air and moisture that got into the system while you were making repairs. Air, refrigerant and moisture do not mix. -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6087 MB (Peak: 0.6784 MB) Data Comp: Off Server Time: 2026-10-24 13:08:35 UTC
