lift kit #1032103 07/24/11 11:45 PM
darren1 Offline OP
I have a 2000 sportage and lookin to lift it around 4", but cant seem to find any? So lookin for help
Re: lift kit [Re: darren1] #1032104 07/25/11 01:12 AM
A
ackerman Offline
Here u go
Upyourkia
01 Sportage 4dr,warn hubs,cone air filter,4" lift,1 3/8" body lift,31" treadwright guard dog mts,Incubus offroad wheels
Re: lift kit [Re: ackerman] #1032105 07/26/11 12:34 AM
darren1 Offline OP
thanks for info!! After doing some reading im now worried that im going to need an adjustable panhard bar? Wondering if this is true and wear i can get my hands on one? Thanks to all!!!
Re: lift kit [Re: darren1] #1032106 07/27/11 02:35 AM
Everet Offline
Everyone that has one of my kits does not have an adjustable pan hard rod (as far as I know). I did a 4" lift to my 2wd 2 door. and drilled a different hole in the passenger side pan hard rod location. It has worked great so far (about 15k miles) with no side effects. If you are having rubbing issues, I can send you a template of what worked for me, NO GUARANTEE it will work for you, but it is the cost of 2 holes.
Re: lift kit [Re: darren1] #1032107 07/27/11 05:04 AM
DennisThompson Offline
I have ran my 4" lift for 12 years and over 160,000 miles and have never installed an addjustible panhard bar. I have never had a problem with allignmens, the rear axle is offseet a little but my tires have allways wore even.
Dennis
Re: lift kit [Re: DennisThompson] #1032108 07/27/11 08:08 AM
2002_Sporty Offline
Running 3" UPYOURKIA.
No issues with lift, panhard rod or uneven wear.
Tire width, hight and backspacing are the only issue I noticed.
2002 4dr Kia Sportage 4X4
Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
Re: lift kit [Re: DennisThompson] #1032109 07/27/11 04:16 PM
homerdog Offline
Same here, I've got a 4" lift, no adjustable panhard bar, never had it aligned after the lift and have close to 40,000 miles on a set of tires with no unusual wear.
2001 Sportage, TJ 106's, Everet spacers and bumpstops, Bilstein shocks on the rear, cone filter, Crager wheels, 235-75-15 Goodyear tires. Custom front winch bumper by Dave Scott. Currently DOA, but it is a work in progress.
2011 Kia Forte EX
Re: lift kit [Re: homerdog] #1032110 08/09/11 12:44 AM
logansportage Offline
I have the TJ rear coils and I get rubbing on my shocks only on the left side when articulating the axle.
I have the stock wheels, but 31x10.5 tires. The stock wheels pull the tires in where an aftermarket wheel with less back spacing will push it out just a touch to keep it from rubbing.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6236 MB (Peak: 0.7058 MB) Data Comp: Off Server Time: 2026-06-07 06:57:40 UTC
