What do they call those sockets that only touch the flat area of a bolt? #1032852 08/08/11 09:55 PM
off-roader Offline OP
I've been thinking of getting a set but can't remember what they're called.
TIA.
Re: What do they call those sockets that only touch the flat area of a bolt? [Re: off-roader] #1032853 08/09/11 12:55 AM
Grasscat Offline
Are you talking about the six-point sockets?
Michael j
TreadLightly! Trainer
Re: What do they call those sockets that only touch the flat area of a bolt? [Re: Grasscat] #1032854 08/09/11 01:51 AM
Spline drive? I have good luck with regular 6pts. Never liked gizmo tools.
Re: What do they call those sockets that only touch the flat area of a bolt? [Re: off-roader] #1032855 08/09/11 01:52 AM
Lots of six point sockets use that design now. Craftsman started doing it maybe ten years ago. Those are probably the least expensive ones made (as I'll bet Snap-On/Matco, etc. cost a "touch" more).
It's standard across the Craftsman line in six-point now.
Re: What do they call those sockets that only touch the flat area of a bolt? [Re: off-roader] #1032856 08/09/11 04:54 AM
hazy_daze Offline
GearWrench (IIRC) makes some that have a slight inward arch that supposedly transfers more of the torque load to the stronger flat rather than the weaker corners. I've used a couple of the larger sockets from a friend's set on an impact gun and it felt like it did less damage to the chrome on my lugnuts. Could've been me "wanting" them to be better, dunno. YMMV... I too am not a fan of tool gimmickry...
Re: What do they call those sockets that only touch the flat area of a bolt? [Re: hazy_daze] #1032857 08/09/11 06:03 PM
Thanks guys. Not the 6 point sockets. I have a set already. I found the ones I'm talking about. They're the Metrinch type of wrenches.
Are the spline drive wrenches supposed to work the same way?
Re: What do they call those sockets that only touch the flat area of a bolt? [Re: off-roader] #1032858 08/10/11 08:26 PM
It looks like the wrench will break before a corner gets rounded off with that design.
Re: What do they call those sockets that only touch the flat area of a bolt? [Re: cmonty72] #1032859 08/11/11 12:35 PM
4ePajero Offline
I know them as C-Profile sockets.
I try to use nothing else.
Don't ascribe to malice anything that can be adequately explained as stupidity!
Pajero LWB Gen1 3.2 Di-D TD Engine
33" Bridgestone D694s
2" Lift
Front Runner Rack
Re: What do they call those sockets that only touch the flat area of a bolt? [Re: 4ePajero] #1032860 08/12/11 08:00 AM
StockRaider Offline
I saw Craftsman sells a set of wrenches that are suppose to not put pressure on the corners.
Re: What do they call those sockets that only touch the flat area of a bolt? [Re: StockRaider] #1032861 08/12/11 08:37 AM
The profile is not as pronounced as the schematic above, but the idea is the same; to exact pressure/torque on the flats of the nuts/fasteners rather than the corners. Therin lies my reference to Craftsman 6-pt sockets and their refinement to the present-day design. Not saying they were the first, but that's where I first noticed it. Makes sense for a lot of wrenches, etc.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6435 MB (Peak: 0.7676 MB) Data Comp: Off Server Time: 2026-05-25 14:56:10 UTC
